Model 629.46979, stand-alone oven/cooktop with center fan. Oven stopped heating. Both elements check at 20 Ohms. No voltage to elements. When I set on Bake and increase temp, after a few seconds I hear a click but still get no voltage or heat. Electronic controls, but clock works and there are no error codes or any indication it's not working. Given what is between the control board and elements, I am thinking it's this relay, the only thing on the back of the oven: WHIRLPOOL BOARD, RELAY W/SHIELD, part number: 12001690AIs there a way to test that relay to know it's bad? Or is there something else that controls the temp/power to the elements? Thanks!
