| » Litton Self cleaning feature doesn't work |
Model Number: 773.000 Brand: -other- Age: More than 10 years
My Litton Microwave Range, model #773 is a combination microwave/oven/stovetop range. It has a self-cleaning feature, but when I try to engage it, nothing happens. The indicator lights don't light up and the oven doesn't heat up.
There are two knobs I set for self cleaning - one is the oven function knob, which I set to 'Clean'. The other knob is the oven temperature setting, which I also set to 'Clean'. I also engage the door lock when setting the self cleaning features on. It behaves as the oven it is not plugged in, but the other oven features work fine. Is there something else I should be doing, as I haven't used this feature for a long time? Is it possible to download or get a user manual for this model anymore? What, if any, troubleshooting steps can I take to determine where the problem might be? Thanks. Howard367 |
Did you get a reply about this... I too have the same problem, need help SfMarinjim@aol.com Mine will lock but will not heat up when set to "clean" in both psoitions. HELP!
| Display Modes | |
| door lock for self cleaning feature | sojourner | Oven Repair (including Ranges and Cooktops) | 0 | 01-17-2008 01:10 PM |
| Stove doesn't work after self-cleaning mode | alfrenzel | Oven Repair (including Ranges and Cooktops) | 9 | 12-13-2007 09:48 PM |
| Oven will not work after self cleaning | Mike Seavey | Oven Repair (including Ranges and Cooktops) | 0 | 09-22-2007 07:44 PM |
| Oven won't heat since I used self cleaning feature | jennyj | Oven Repair (including Ranges and Cooktops) | 1 | 09-19-2007 08:15 PM |
| Self cleaning feature won't work | morganp | Oven Repair (including Ranges and Cooktops) | 0 | 09-16-2007 09:22 AM |
