Discuss
Thermador Range Grill Gas Valve Needed
 in
I think I have diagnosed my problem and found the correct replacement part but would like confirmation. The grill on
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Range Grill Gas Valve Needed
  #1 (permalink)
Old 08-24-2009, 10:43 AM
Junior Member
DonD is on a distinguished road
Default Thermador Range Grill Gas Valve Needed
Model Number: PRDS364GL   Brand: Thermador   Age: More than 10 years
I think I have diagnosed my problem and found the correct replacement part but would like confirmation. The grill on my Thermador PRDS364GL range doesn't light. See here for parts (http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232615)
I checked the circuit and have measured 120 VAC going into the valve (http://www.appliancepartspros.com/pa...e l_id=232615) item 87, Part Number: AP2832925 made by BOSCH, but 0 volts coming out. I assume this is not normal and indicates that I need to replace it, right? Or is there something else I am not understanding.
Also, the valve has been replaced once already several years ago. The part that is in there now is a NC-4125-5 Eaton Bi-Metal Gas Valve but it clearly marked "do not apply 120 VAC" and is marked 3.03/3.3 VAC. I am measuring 120 VAC going into the valve so is it safe to assume that the repair guy (under warranty) replaced the valve with the wrong part. It's lasted for years but I assume that applying 120 VAC to this probably burnt it out, right?
I need a little reassurance that replacing this will correct the problem before spending $100+ on it. I also just replaced the igniter.
Help from a APP technician would be appreciated ASAP as I'd like to order this part today.
Finally, do you recommend and sell a good sealant for the gas line since I need to break the gas line to replace the valve?
Thanks,
Don
Ads By Google
Related Models
Thermador PRDS364GL
Thermador PRDS366
Thermador PRDS484GD
Thermador PRDS484GG
Thermador PRDS484GL
Thermador PRDS486GD
Thermador PRDS486GL
Jenn-Air PRG3000P Range - S/c F/s Gas
Jenn-Air PRG3010LP Range - S/c F/s Gas
Jenn-Air PRG3010NP Range - S/c F/s Gas
Thermador PRG304US
Jenn-Air PRG3601P Range - S/c F/s Gas
Jenn-Air PRG3610LP Range - S/c F/s Gas
Jenn-Air PRG3610NP Range - S/c F/s Gas
Thermador PRG364GD
Thermador PRG364GDUS
Thermador PRG364GL
Thermador PRG364GLUS
Thermador PRG366
Thermador PRG366US
Jenn-Air PRG4802P Range - S/c F/s Gas
Jenn-Air PRG4810LP Range - S/c F/s Gas
Jenn-Air PRG4810NP Range - S/c F/s Gas
Thermador PRG484GGUS
Amana PRH08333A Room Air Conditioner
Amana PRH13333A Room Air Conditioner
Thermador PRSE304S
Thermador PRSE364GDS
Thermador PRSE364GLS
Thermador PRSE366S
Thermador PRSE484GGS
Thermador PRSE486GDS
Thermador PRSE486GLS
Thermador PRSG304
Thermador PRSG364GD
Thermador PRSG366
Frigidaire PRT134PCD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCH0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT134PCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT134PCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT134PCW3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT154MCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCD5 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT154MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCH2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCW1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT154MCW2 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCW3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT154MCW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT154MCW5 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT173HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT173MCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCD3 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCH2 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT173MCH3 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT173MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT173MCW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCW2 Wwh(v6) / Top Mount Refrigerator
Frigidaire PRT173MCW3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT173MCW4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193MCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD3 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCD4 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCD6 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193MCH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCH1 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCH3 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT193MCH4 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT193MCW1 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT193MCW3 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT193MCW4 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT193MCW6 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT215MCD5 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT215MCW5 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217HD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217HF0 Wwh(v4) / Top Mount Refrigerator
Frigidaire PRT217HH0 Wwh(v3) / Top Mount Refrigerator
Frigidaire PRT217HV0 Wwh(v2) / Top Mount Refrigerator
Frigidaire PRT217HW0 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217MCD1 Wwh(v5) / Top Mount Refrigerator
Frigidaire PRT217MCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire PRT217MCD3 Wwh(v1) / Top Mount Refrigerator
  #2 (permalink)
Old 08-24-2009, 01:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Don,
Have you checked for 120 VAC to the igniter while the control calls for heat?
The gas safety valve has to be checked for continuity only.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 08-24-2009, 06:32 PM
Junior Member
Default
Hi Gene - the valve is an open circuit. I see about 1.6 VAC across the ignitor when I start the grill. I hope this means that the valve is bad since I already ordered one.
Does the 3.3 V valve in there now make any sense to you?
Thanks for the reply,
Don
  #4 (permalink)
Old 08-29-2009, 12:37 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Don,
Sorry for the delay. If the gas valve is open then you are on the right way. Keep us posted.
__________________
  #5 (permalink)
Old 08-31-2009, 02:55 PM
Junior Member
Default
The valve replacement was successful but I don't understand one thing. The replacement valve was exactly same as the bad one I removed. Ordinarily that would be a good thing but now I go back to my original question:
Why is the valve clearly marked "do not apply 120 VAC" and is marked 3.03/3.3 VAC? The input wire is 120 VAC. What am I missing?
I hope you have some time for lots of questions. One of the XLO burners just quit and the ovens ability to come up to temperature has been inconsistant for a while...
I'll post those question in other respective threads.
  #6 (permalink)
Old 08-31-2009, 05:35 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The valve is connected in series with the igniter and because of the igniter resistance the voltage in the circuit is much less than 120 VAC.
I'm glad you were able to fix it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Grill Erratic ruscar Oven Repair (including Ranges and Cooktops) 5 11-03-2009 11:29 PM
How to exchange broken burner valve on Thermador Range patrikf Oven Repair (including Ranges and Cooktops) 2 05-21-2009 05:44 AM
Thermador Range top valve stem spf 72 Oven Repair (including Ranges and Cooktops) 1 03-16-2009 04:54 PM
Thermador Gas Grill s11845 Microwave Repair 1 03-09-2009 07:25 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
