Discuss
Tappan tapped out
 in
This oven/range has been a real workhorse, and zero problems until now. After the last self-clean, the oven is not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan tapped out
  #1 (permalink)
Old 03-31-2012, 01:53 PM
Junior Member
shocked is on a distinguished road
Default Tappan tapped out
Model Number: 31-2649-00/07   Brand: Tappan   Age: More than 10 years
This oven/range has been a real workhorse, and zero problems until now. After the last self-clean, the oven is not working properly, but the stovetop is fine and functional. The symptoms are as follows;
  • The oven lights do not come on.
  • The oven heats, but not much; maybe 200 degrees F.
  • The broiler no longer functions.
  • The oven element never gets "red".
  • I confess to not knowing if the thermostat "wire" was "dangling" previously, but it is now; apparently it was dislodged from its holder on the oven side, and now dangles at the rear of the oven.
  • In looking at some other posts and responses, I am guessing that there are two possibilities;
    1. A new thermostat needs to be installed.
    2. A new control panel is needed.
Your thoughts, and do you have the suggested parts on hand, if needed, along with instructions for installation?
Thanks so much! I'm so glad I found this forum and site
Ads By Google
Related Models
Frigidaire 31-2649-23-02 Tap(v2) / Electric Range
Frigidaire 31-2649-23-03 Tap(v4) / Electric Range
Frigidaire 31-2649-23-04 Tap(v2) / Electric Range
Frigidaire 31-2649-23-05 Tap(v2) / Electric Range
Frigidaire 31-2649-23-06 Tap(v3) / Electric Range
Frigidaire 31-2649-23-07 Tap(v4) / Electric Range
Frigidaire 31-2649-23-08 Tap(v2) / Electric Range
Frigidaire 31-2649-23-09 Tap(v2) / Electric Range
Frigidaire 31-2649-23-10 Tap(v2) / Electric Range
Frigidaire 31-2752-00-01 Tap(v1) / Electric Range
Frigidaire 31-2752-00-02 Tap(v1) / Electric Range
Frigidaire 31-2752-00-03 Tap(v1) / Electric Range
Frigidaire 31-2752-23-01 Tap(v2) / Electric Range
Frigidaire 31-2752-23-02 Tap(v2) / Electric Range
Frigidaire 31-2752-23-03 Tap(v2) / Electric Range
Frigidaire 31-2757-00-01 Tap(v1) / Range
Frigidaire 31-2757-00-02 Tap(v4) / Range
Frigidaire 31-2757-23-01 Tap(v2) / Range
Frigidaire 31-2757-23-02 Tap(v5) / Range
Frigidaire 31-2757-66-01 Tap(v3) / Range
Frigidaire 31-2757-66-02 Tap(v6) / Range
Frigidaire 31-2758-00-01 Tap(v1) / Electric Range
Frigidaire 31-2758-00-02 Tap(v2) / Electric Range
Frigidaire 31-2758-00-03 Tap(v1) / Electric Range
Frigidaire 31-2758-00-04 Tap(v7) / Electric Range
Frigidaire 31-2758-00-05 Tap(v1) / Electric Range
Frigidaire 31-2758-23-01 Tap(v2) / Electric Range
Frigidaire 31-2758-23-02 Tap(v4) / Electric Range
Frigidaire 31-2758-23-03 Tap(v2) / Electric Range
Frigidaire 31-2758-23-04 Tap(v8) / Electric Range
Frigidaire 31-2758-23-05 Tap(v2) / Electric Range
Frigidaire 31-2758-66-01 Tap(v3) / Electric Range
Frigidaire 31-2758-66-02 Tap(v6) / Electric Range
Frigidaire 31-2758-66-03 Tap(v3) / Electric Range
Frigidaire 31-2758-66-04 Tap(v9) / Electric Range
Frigidaire 31-2758-66-05 Tap(v3) / Electric Range
Frigidaire 31-2759-00-01 Tap(v1) / Electric Range
Frigidaire 31-2759-00-02 Tap(v1) / Electric Range
Frigidaire 31-2759-00-03 Tap(v3) / Electric Range
Frigidaire 31-2759-00-04 Tap(v1) / Electric Range
Frigidaire 31-2759-00-05 Tap(v1) / Electric Range
Frigidaire 31-2759-23-01 Tap(v2) / Electric Range
Frigidaire 31-2759-23-02 Tap(v2) / Electric Range
Frigidaire 31-2759-23-03 Tap(v4) / Electric Range
Frigidaire 31-2759-23-04 Tap(v2) / Electric Range
Frigidaire 31-2759-23-05 Tap(v2) / Electric Range
Frigidaire 31-2769-00-01 Tap(v1) / Electric Range
Frigidaire 31-2769-23-01 Tap(v2) / Electric Range
Frigidaire 31-2852-00-01 Tap(v1) / Electric Range
Frigidaire 31-2852-00-02 Tap(v3) / Electric Range
Frigidaire 31-2852-00-03 Tap(v1) / Electric Range
Frigidaire 31-2852-23-01 Tap(v2) / Electric Range
Frigidaire 31-2852-23-02 Tap(v4) / Electric Range
Frigidaire 31-2852-23-03 Tap(v2) / Electric Range
Frigidaire 31-2862-00-01 Tap(v1) / Electric Range
Frigidaire 31-2862-00-02 Tap(v5) / Electric Range
Frigidaire 31-2872-23-01 Tap(v1) / Electric Range
Frigidaire 31-2872-23-02 Tap(v6) / Electric Range
Frigidaire 31-2872-23-03 Tap(v0) / Electric Range
Frigidaire 31-2977-00-01 Tap(v1) / Electric Range
Frigidaire 31-2977-23-01 Tap(v2) / Electric Range
Frigidaire 31-2979-00-01 Tap(v1) / Electric Range
Frigidaire 31-3138-00-05 Tap(v1) / Electric Range
Frigidaire 31-3138-23-05 Tap(v2) / Electric Range
Frigidaire 31-3138-66-05 Tap(v3) / Electric Range
Frigidaire 31-3342-00-01 Tap(v1) / Electric Range
Frigidaire 31-3342-00-02 Tap(v1) / Electric Range
Frigidaire 31-3342-23-01 Tap(v2) / Electric Range
Frigidaire 31-3342-23-02 Tap(v2) / Electric Range
Frigidaire 31-3347-00-01 Tap(v1) / Range
Frigidaire 31-3347-00-02 Tap(v1) / Electric Range
Frigidaire 31-3347-00-03 Tap(v1) / Electric Range
Frigidaire 31-3347-23-01 Tap(v2) / Range
Frigidaire 31-3347-23-03 Tap(v2) / Electric Range
Frigidaire 31-3347-66-01 Tap(v3) / Range
Frigidaire 31-3347-66-03 Tap(v3) / Electric Range
Frigidaire 31-3348-00-03 Tap(v1) / Electric Range
Frigidaire 31-3348-00-04 Tap(v4) / Electric Range
Frigidaire 31-3348-00-05 Tap(v1) / Electric Range
Frigidaire 31-3348-23-03 Tap(v2) / Electric Range
Frigidaire 31-3348-23-04 Tap(v5) / Electric Range
Frigidaire 31-3348-23-05 Tap(v2) / Electric Range
Frigidaire 31-3348-66-03 Tap(v3) / Electric Range
Frigidaire 31-3348-66-04 Tap(v6) / Electric Range
Frigidaire 31-3348-66-05 Tap(v3) / Electric Range
Frigidaire 31-3349-00-01 Tap(v1) / Electric Range
Frigidaire 31-3349-00-03 Tap(v3) / Electric Range
Frigidaire 31-3349-00-04 Tap(v1) / Electric Range
Frigidaire 31-3349-00-05 Tap(v1) / Electric Range
Frigidaire 31-3349-23-01 Tap(v2) / Electric Range
Frigidaire 31-3349-23-02 Tap(v2) / Electric Range
Frigidaire 31-3349-23-03 Tap(v4) / Electric Range
Frigidaire 31-3349-23-04 Tap(v2) / Electric Range
Frigidaire 31-3349-23-05 Tap(v2) / Electric Range
Frigidaire 31-3437-00-01 Tap(v1) / Electric Range
Frigidaire 31-3437-00-02 Tap(v4) / Electric Range
Frigidaire 31-3437-00-03 Tap(v7) / Electric Range
Frigidaire 31-3437-23-01 Tap(v2) / Electric Range
Frigidaire 31-3437-23-02 Tap(v5) / Electric Range
Frigidaire 31-3437-23-03 Tap(v8) / Electric Range
Frigidaire 31-3437-66-01 Tap(v3) / Electric Range
Frigidaire 31-3437-66-02 Tap(v6) / Electric Range
Frigidaire 31-3437-66-03 Tap(v9) / Electric Range
Frigidaire 31-3438-00-01 Tap(v1) / Electric Range
Frigidaire 31-3438-00-02 Tap(v4) / Electric Range
Frigidaire 31-3438-00-03 Tap(v7) / Electric Range
Frigidaire 31-3438-00-04 Tap(v10) / Electric Range
Frigidaire 31-3438-00-05 Tap(v1) / Electric Range
Frigidaire 31-3438-00-06 Tap(v4) / Electric Range
Frigidaire 31-3438-23-01 Tap(v2) / Electric Range
Frigidaire 31-3438-23-02 Tap(v5) / Electric Range
Frigidaire 31-3438-23-03 Tap(v8) / Electric Range
Frigidaire 31-3438-23-04 Tap(v11) / Electric Range
Frigidaire 31-3438-23-05 Tap(v2) / Electric Range
Frigidaire 31-3438-23-06 Tap(v5) / Electric Range
Frigidaire 31-3438-66-01 Tap(v3) / Electric Range
Frigidaire 31-3438-66-02 Tap(v6) / Electric Range
Frigidaire 31-3438-66-03 Tap(v9) / Electric Range
Frigidaire 31-3438-66-04 Tap(v12) / Electric Range
Frigidaire 31-3438-66-05 Tap(v3) / Electric Range
  #2 (permalink)
Old 04-07-2012, 09:04 AM
Junior Member
Default
I take back my compliment... appliance shmucks is a more apt description; not even the courtesy of a reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
old tappan tappan double oven bottom turns on top oven wont jcole9969 Oven Repair (including Ranges and Cooktops) 9 02-28-2011 08:17 AM
Kitchenaid Oven will not heat up unless valve is tapped on evelyn915 Oven Repair (including Ranges and Cooktops) 0 10-19-2009 08:59 AM
Old Tappan EOC Eug28 Oven Repair (including Ranges and Cooktops) 1 02-05-2009 04:41 PM
Tappan janna57 Oven Repair (including Ranges and Cooktops) 1 01-24-2009 05:53 AM
tappan ali12414 Oven Repair (including Ranges and Cooktops) 0 11-03-2007 10:03 AM
