Discuss
Whirlpool Control Panel
 in
I received an error code on my electric oven of F3E2. Based on some blogs and speaking with a representative
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Control Panel
  #1 (permalink)
Old 01-18-2008, 10:54 AM
vfourider vfourider is offline
Junior Member
vfourider is on a distinguished road
Default Whirlpool Control Panel
Model Number: RF378LXMT   Brand: Whirlpool   Age: 1 - 5 years
I received an error code on my electric oven of F3E2. Based on some blogs and speaking with a representative at Whirlpool, I was told I would need to replace my control panel part # 6610454 which I did. The oven still does not work properly. Both the broiler and the lower heating elements light and it is not maintaining the proper temperature (way too hot). Is it possible I replaced the wrong part or received a new faulty part? What else would I need to replace?
Please help.
Vince
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-28-2008, 07:53 PM
Junior Member
Default Whirlpool Control Board error code F3E2
I see a lot of views on my issue, but no suggestions. Can any of you techs out there offer a remedy? I spoke with two different techs and reviewed whirlpools factory specs/repair manual and all state to check the oven temperature sensor with an ohm meter which should state at or near 1100 ohms. If the sensor, the connectors and the wire harness to the sensor are OK, the issue is with the control board which I replaced and still the oven overheats and does not maintain the proper temperature. Come on you appliance pros, write me back with a suggestion.........
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control panel-8.8. jmcnulty Dryer Repair 0 12-30-2007 12:34 PM
control panel smueller Dryer Repair 0 12-30-2007 12:03 PM
control panel Joef Oven Repair (including Ranges and Cooktops) 0 12-20-2007 10:35 AM
Do I have a bad control panel? wenoch01 Oven Repair (including Ranges and Cooktops) 4 11-05-2007 05:51 PM
Control Panel lockout Washman Dishwasher Repair 8 10-08-2007 10:00 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
