Discuss
Need Replacement Control Panel for Kenmore Double Oven
 in
The clock/timer (P/N 330938 or 4336454) on my double oven control panel is broken and I can't find a new
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Need Replacement Control Panel for Kenmore Double Oven
  #1 (permalink)
Old 03-31-2012, 08:43 AM
Junior Member
lewtyler is on a distinguished road
Question Need Replacement Control Panel for Kenmore Double Oven
Model Number: 278.4298493   Brand: Kenmore   Age: More than 10 years
The clock/timer (P/N 330938 or 4336454) on my double oven control panel is broken and I can't find a new or reconditioned one.
My question is, since the ovens are still in perfect working order, is it possible to replace this old control panel with a newer, digital unit? I would think that the input/output lines to the ovens should be the same and I could work around any differences in connectors.
Matching the physical dimensions might be the main problem -- the panel size at the face plate is 26 3/4 inches wide by 9 5/8 inches high.
Any help you can give will be appreciated.
Lew
Ads By Google
Related Models
Hoover 2800
Frigidaire 2803 GAS RANGE
Frigidaire 2803-80B GAS RANGE
Frigidaire 28044 FRIGIDAIRE GAS RANGE
Frigidaire 280440C GAS RANGE
Frigidaire 280447C GAS RANGE
Frigidaire 2809A GAS RANGE
Frigidaire 2811 GAS RANGE
Frigidaire 2812A GAS RANGE
Frigidaire 2813-80B GAS RANGE
Frigidaire 2813A GAS RANGE
Frigidaire 2819A GAS RANGE
Frigidaire 2820A GAS RANGE
Frigidaire 282240A GAS RANGE
Frigidaire 282240B GAS RANGE
Frigidaire 282240C GAS RANGE
Frigidaire 282247B GAS RANGE
Frigidaire 282247C GAS RANGE
Frigidaire 2822A GAS RANGE
Frigidaire 2823 GAS RANGE
Frigidaire 2823-80B GAS RANGE
Frigidaire 2828A GAS RANGE
Frigidaire 2829A GAS RANGE
Hoover 2830
Frigidaire 2833 GAS RANGE
Frigidaire 2833-80B GAS RANGE
Frigidaire 2834-80A GAS RANGE
Frigidaire 2834-80B FRIGIDAIRE GAS RANGE
Frigidaire 2834-87B FRIGIDAIRE GAS RANGE
Frigidaire 283440A GAS RANGE
Frigidaire 283440B GAS RANGE
Frigidaire 283440C FRIGIDAIRE GAS RANGE
Frigidaire 283440D GAS RANGE
Frigidaire 283447B GAS RANGE
Frigidaire 283447C FRIGIDAIRE GAS RANGE
Frigidaire 283447D GAS RANGE
Frigidaire 283460B GAS RANGE
Frigidaire 283460C GAS RANGE
Frigidaire 283467B GAS RANGE
Frigidaire 283467C GAS RANGE
Hoover 2836
Frigidaire 28364 GAS RANGE
Frigidaire 2841A GAS RANGE
Frigidaire 284260A GAS RANGE
Frigidaire 284267A GAS RANGE
Frigidaire 2843-80A GAS RANGE
Frigidaire 2843-80B GAS RANGE
Frigidaire 2843-80C GAS RANGE
Roper 2843W0A Ranges, Electric*
Frigidaire 284440A GAS RANGE
Frigidaire 284440B GAS RANGE
Frigidaire 284447A GAS RANGE
Frigidaire 284447B GAS RANGE
Frigidaire 2851A GAS RANGE
Frigidaire 2853 GAS RANGE
Frigidaire 28564 FRIGIDAIRE GAS RANGE
Frigidaire 285640A FRIGIDAIRE GAS RANGE
Frigidaire 285640B GAS RANGE
Frigidaire 285640D GAS RANGE
Frigidaire 285640E GAS RANGE
Frigidaire 285647A FRIGIDAIRE GAS RANGE
Frigidaire 285647B GAS RANGE
Frigidaire 285647D GAS RANGE
Frigidaire 285647E GAS RANGE
Frigidaire 285660A GAS RANGE
Frigidaire 285667A GAS RANGE
Frigidaire 28584 GAS RANGE
Frigidaire 285840A GAS RANGE
Frigidaire 285840B GAS RANGE
Frigidaire 285840C GAS RANGE
Frigidaire 285840D GAS RANGE
Frigidaire 285847A GAS RANGE
Frigidaire 285847B GAS RANGE
Frigidaire 285847C GAS RANGE
Frigidaire 285847D GAS RANGE
Frigidaire 28586 FRIGIDAIRE GAS RANGE
Frigidaire 285860A GAS RANGE
Frigidaire 285860B FRIGIDAIRE GAS RANGE
Frigidaire 285860C FRIGIDAIRE GAS RANGE
Frigidaire 285867A GAS RANGE
Frigidaire 28594 FRIGIDAIRE GAS RANGE
Frigidaire 285940A FRIGIDAIRE GAS RANGE
Frigidaire 285940B GAS RANGE
Frigidaire 285941A FRIGIDAIRE GAS RANGE
Frigidaire 285947A FRIGIDAIRE GAS RANGE
Frigidaire 285947B GAS RANGE
Frigidaire 2859A GAS RANGE
Frigidaire 2861A GAS RANGE
Frigidaire 2864 GAS RANGE
Frigidaire 2864-80B GAS RANGE
Frigidaire 2869A GAS RANGE
Frigidaire 2871A GAS RANGE
Roper 2872*0A Ranges, Electric*
Frigidaire 2872A GAS RANGE
Roper 2872W0A Ranges, Electric*
Frigidaire 2873 GAS RANGE
Frigidaire 2873B GAS RANGE
Frigidaire 2879A GAS RANGE
Frigidaire 2881 GAS RANGE
Frigidaire 2883 GAS RANGE
Roper 2883*10 Ranges, Electric*
Frigidaire 2883-80A GAS RANGE
Frigidaire 2883-81A GAS RANGE
Frigidaire 2883-81B GAS RANGE
Roper 2883W10 Ranges, Electric*
Frigidaire 2889A GAS RANGE
Frigidaire 2891 GAS RANGE
Frigidaire 2893 GAS RANGE
Roper 2893*0A Ranges, Electric*
Frigidaire 2893-80B GAS RANGE
Roper 2893W0A Ranges, Electric*
Frigidaire 2899A GAS RANGE
Magic Chef 28FA-6CXWV8 RANGE- S/C MWAVE ELE
Magic Chef 28FA-6CXWV8-94 RANGE- S/C MWAVE ELE
Magic Chef 28FA-6CXWV8-DZ RANGE- S/C MWAVE ELE
Magic Chef 28FA-7CVWV8-94 RANGE- S/C MWAVE ELE
Magic Chef 28FA-7CXW WALLOVEN-S/C DBL OVEN ELE
Magic Chef 28FA-7CXW-19 WALLOVEN-S/C DBL OVEN ELE
Magic Chef 28FA-7CXW-94 WALLOVEN-S/C DBL OVEN ELE
Magic Chef 28FA-7CXWV8 RANGE- S/C MWAVE ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Double Wall Oven New COntrol Panel laurapre1 Oven Repair (including Ranges and Cooktops) 0 11-20-2011 09:03 AM
Kenmore Gas Oven Control Panel replacement j.clayton Oven Repair (including Ranges and Cooktops) 1 02-12-2010 05:51 PM
Kenmore Gas Oven Control Panel replacement j.clayton Oven Repair (including Ranges and Cooktops) 1 02-12-2010 05:50 PM
GE Double Oven Control Panel replacement robwinter Oven Repair (including Ranges and Cooktops) 0 12-12-2009 11:52 AM
Double Oven control Panel nansells Oven Repair (including Ranges and Cooktops) 2 05-25-2009 04:41 PM
