| » Hinge adjustment on GE Monogram wall oven ZET1038? |
Model Number: ZET1038 Brand: GE Age: 5 - 10 years
The oven door on our GE wall oven won't stay all the way shut when I close it, so I had been assuming the hinges need to be repaired. So I removed the door and pulled the oven out enough to remove the hinge brackets. It appears that on this model, though, you have to replace the entire hinge bracket assemblies at ~$66 each. Before I do spend that much money on parts, is there anything else I might be able to do in terms of adjusting how the hinges close? The assemblies themselves look pretty good -- I don't see anything that appears broken.
Thanks, mike Ads By Google Related Models |
| Display Modes | |
| door hinge adjustment | mark2011 | Oven Repair (including Ranges and Cooktops) | 0 | 03-15-2011 01:46 PM |
| GE Monogram 27" oven door hinge rpr | Steve Dall | Oven Repair (including Ranges and Cooktops) | 1 | 01-17-2011 03:02 PM |
| oven temp adjustment | jmiller5927 | Oven Repair (including Ranges and Cooktops) | 0 | 03-30-2010 02:43 PM |
| oven door hinge broke,so did hinge post for top | Melodygmd | Oven Repair (including Ranges and Cooktops) | 1 | 12-30-2008 04:32 PM |
| Tappan Wall Oven Temp adjustment | jmdrapeau | Oven Repair (including Ranges and Cooktops) | 1 | 09-29-2007 11:15 AM |
