I'm Starting A New Post Because Of The Wrong Model Number I Used Previously. When I Use This Model # To Find Parts At This Website, It Brings Up The Correct Parts Pages. In Your Last Post You Said Since I Changed The Switch And That Didn't Fix It Then The Element Needs To Be Changed.
Just To Repeat My Problem, I Have A Ge Stovetop That Has A Glass Top. There Is One Burner That Has A Small And Large Element . The Small Works Fine But I Get Nothing From The Large One. I Changed The Switch For This Burner But Still Nothing. Do You Still Think It Is The Element That Needs Replacing?
Originally Posted by: stevemac51 ...Do You Still Think It Is The Element That Needs Replacing?... Yes, I do. Especially if there is nothing wrong with the wires. I'm glad you were able to find the correct model number. - The dual heating element Part number: AP2027786
