| » Jenn Air Oven not heating and light comes on by itself |
Model Number: JGS9900BDS Brand: Jenn-Air Age: 5 - 10 years
Hello,
My Jenn-Air recently stopped heating and the light comes on and off by itself. The light can also be turned off at the control panel. Gas burners work fine. I ordered the complete control panel and it worked for about 2 weeks(although light still occasionally did not work). Ordered another panel,replaced and oven doesn't work at all, light still comes on and oven goes into preheat cycle and then shuts down. You have to hit cancel to get the control panel to respond to button presses. I hear beeping coming from the unit sporadically. Oven has not been repaired before, this is new. Thanks, Todd Ads By Google Related Models |
Hi Todd,
Sounds like the problem is a bad control board. - The control board Part number: AP4507648 Here are the breakdown diagrams and Replacement parts for Jenn-Air JGS9900BDS RANGE- S/C S/I DDRAFT GAS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Todd,
Every part has its own name and it is very important for proper troubleshooting to name it right. The control panel is the face panel with a key pads on it. According to the problem description you posted, the first problem suspect is a faulty control panel. I did recommend to replace the control board because you stated that you already replaced the control panel twice and it did not fix the problem. Now we found that you actually replaced the control board and the next step is to replace the control panel. - The control panel Part number: AP4371193 Gene.
__________________
Click on the picture and you'll see a few different views. You can see a ribbon cable in one of them. It plugs into the control board which you said you replaced twice.
__________________
| Display Modes | |
| Jenn-Air Range, oven not heating | Mark Wise | Oven Repair (including Ranges and Cooktops) | 7 | 05-05-2013 09:40 AM |
| Non heating Top Oven Electric Jenn-Air | gogto | Oven Repair (including Ranges and Cooktops) | 0 | 06-20-2011 08:33 PM |
| Jenn-air oven won't light | bigpapahawk | Oven Repair (including Ranges and Cooktops) | 0 | 10-10-2010 04:58 AM |
| Blinking Blue Lights (Oven ON Light & Oven Heating Light | bubbah2os | Oven Repair (including Ranges and Cooktops) | 1 | 02-05-2010 01:07 PM |
| Jenn Air Wall Oven - Not Heating | jreadhead | Oven Repair (including Ranges and Cooktops) | 0 | 11-19-2009 11:17 AM |
