Discuss
Oven door trim replacement
 in
I need to replace the white trim along the sides and bottom of both the upper and lower oven doors.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven door trim replacement
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-17-2008, 10:30 AM
FranklinD FranklinD is offline
Junior Member
FranklinD is on a distinguished road
Default Oven door trim replacement
Model Number: MER6772BAW   Brand: Maytag   Age: 1 - 5 years
I need to replace the white trim along the sides and bottom of both the upper and lower oven doors. The trim has rusted through. I have three questions.
1. For the upper door, Part Number 14 in your exploded diagram is listed as "Frame/tape assembly", and is the part I need to replace. Part Number 16 in your diagram is listed as "Foil Tape." What is the foil tape for, and do I need it to replace the trim? If so, do I need to order two of them--one for each side of the oven door? Also, there are two line items for the frame/tape assembly, but no color is indicated. Is part number AP376663 the white one?
2. For the lower door, Part Number 18 in your exploded diagram is listed as "Kit, door trim (wht)", and is the part I need to replace. Part Numbers 17 and 19 are listed as "Tape, dbl. sided." What is the tape for, and do I need it to replace the trim?
3. Do you have any ideas why, after less than three years, these door trim pieces have rusted to the point of disintegration? Is this a common problem, or should I assume that the original trim was somehow defective? No other parts of the range have rusted.
Thank you very much for your help...
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-22-2008, 12:40 PM
Adam / APP Team Adam / APP Team is offline
Service Pro
APP Team
Adam / APP Team is on a distinguished road
Default
Dear FranklinD,
For the model # MER6772BAW the upper door trim in white you will need to order part number AP376663. That includes the tape that runs along the inside covering the bottom and two sides of the upper door.
For the same on the lower door you need to order part number AP3718217
The tape is to provide a good seal between the glass and trim. You might consider ordering just in case you need more.
As far as why it is rusting so soon could be just from moisture getting through the paint when liquid stays on the trim after it has been cleaned.
If you still have questions or need parts please feel free to contact our call center toll free at 1-877-477-7278 and a representative will be glad to help you or use our live chat feature.
__________________
Need a part? Buy appliance parts from us. Fast delivery and great prices.
Thank you for supporting our free repair help forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven door replacement options morogr Oven Repair (including Ranges and Cooktops) 6 09-30-2008 06:07 PM
How to replace bezel trim on Magic Chef oven 44556677oven Oven Repair (including Ranges and Cooktops) 8 07-26-2008 01:10 PM
Microwave Door Replacement smc6429 Microwave Repair 0 11-04-2007 06:03 PM
Trying to repair trim on door fmacchia Refrigerator & Freezer Repair 0 10-09-2007 03:38 PM
Oven Outer Door Replacement cnowen Oven Repair (including Ranges and Cooktops) 1 09-08-2007 01:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
