Discuss
Oven won't heat up at all.
 in
Hi, Hope I can get some suggestions regarding our range. A few days ago, the oven decided it would not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't heat up at all.
  #1 (permalink)
Old 07-19-2007, 10:07 PM
acillatem acillatem is offline
Junior Member
acillatem is on a distinguished road
Default Oven won't heat up at all.
Model Number: KERC506HWH2   Brand: Kitchen Aid   Age: 5 - 10 years
Hi, Hope I can get some suggestions regarding our range. A few days ago, the oven decided it would not heat up, just out of the blue. It worked fine the night before. The display shows that it is on, the temp, etc..........just no heat. The fan is coming on, but all the heating elements are cold.......no heat at all. It was suggested by a couple people that it may be a heating element, or most likely the ERC board. Correct me If I'm wrong, but all 3 heating elements in the oven wouldn't go out at the same time, correct? If one was out the other two would still work, I'm assuming. Based on that, I took a chance and ordered the new ERC board from here.........it arrived today, I put it in, and no change at all. Now I've spent $165, and still have an oven that doesn't heat up, and a non returnable part. The only good thing that came out of that is the buttons are much easier to push than the old board. They were never easy, and we asked the service guy about it when he was fixing something else, and he said it was normal because of the way the board attches to the control panel, and we believed him. Anyway, at least there is a positive to the new ERC board, but the oven still doesn't heat up.Any ideas??? Could it be the oven temperature sensor? I'm running out of things it could be, I think. Any help greatly appreciated. Thanks in advance!
Related Models
Whirlpool KERC506HWH2
Whirlpool KERC506HWH3 30" Electric Range Ceran Cooktop Convection Oven
Whirlpool KERC507EAL1
Whirlpool KERC507EAL2
Whirlpool KERC507EAL3
Whirlpool KERC507EAL4
Whirlpool KERC507EAL5
Whirlpool KERC507EBL1
Whirlpool KERC507EBL2
Whirlpool KERC507EBL3
Whirlpool KERC507EBL4
Whirlpool KERC507EBL5
Whirlpool KERC507EWH1
Whirlpool KERC507EWH2
Whirlpool KERC507EWH3
Whirlpool KERC507EWH4
Whirlpool KERC507EWH5
Whirlpool KERC507HAL0
Whirlpool KERC507HAL1
Whirlpool KERC507HAL2
Whirlpool KERC507HAL3
Whirlpool KERC507HBL0
Whirlpool KERC507HBL1
Whirlpool KERC507HBL2
Whirlpool KERC507HBL3
Whirlpool KERC507HBL4
Whirlpool KERC507HBS0
Whirlpool KERC507HBS1
Whirlpool KERC507HBS2
Whirlpool KERC507HBS3
Whirlpool KERC507HBS4
Whirlpool KERC507HBT0
Whirlpool KERC507HBT1
Whirlpool KERC507HBT2
Whirlpool KERC507HBT3
Whirlpool KERC507HBT4
Whirlpool KERC507HWH0
Whirlpool KERC507HWH1
Whirlpool KERC507HWH2
Whirlpool KERC507HWH3
Whirlpool KERC507HWH4
Whirlpool KERC507YAL0
Whirlpool KERC507YAL1
Whirlpool KERC507YAL2
Whirlpool KERC507YAL3
Whirlpool KERC507YAL4
Whirlpool KERC507YAL5
Whirlpool KERC507YWH0
Whirlpool KERC507YWH1
Whirlpool KERC507YWH2
Whirlpool KERC507YWH3
Whirlpool KERC507YWH4
Whirlpool KERC507YWH5
Whirlpool KERC508LSS0 30" Electronic Range Freestanding Designer Style
Whirlpool KERC600EAL0
Whirlpool KERC600EAL1
Whirlpool KERC600EAL2
Whirlpool KERC600EAL5
Whirlpool KERC600EWH0
Whirlpool KERC600EWH1
Whirlpool KERC600EWH2
Whirlpool KERC600EWH5
Whirlpool KERC600GAL0
Whirlpool KERC600GAL1
Whirlpool KERC600GBS0
Whirlpool KERC600GBS1
Whirlpool KERC600GWH0
Whirlpool KERC600GWH1
Whirlpool KERC600HBS0
Whirlpool KERC600HBT0
Whirlpool KERC600HWH0
Whirlpool KERC601HBL4
Whirlpool KERC601HBL6
Whirlpool KERC601HBL8
Whirlpool KERC601HBT0
Whirlpool KERC601HBT1
Whirlpool KERC601HBT3
Whirlpool KERC601HBT4
Whirlpool KERC601HBT5
Whirlpool KERC601HBT6
Whirlpool KERC601HBT8
Whirlpool KERC601HWH0
Whirlpool KERC601HWH1
Whirlpool KERC601HWH3
Whirlpool KERC601HWH4
Whirlpool KERC601HWH5
Whirlpool KERC601HWH6
Whirlpool KERC601HWH8
Whirlpool KERC607EAL0
Whirlpool KERC607EAL1
Whirlpool KERC607EAL2
Whirlpool KERC607EAL4
Whirlpool KERC607EAL5
Whirlpool KERC607EWH0
Whirlpool KERC607EWH1
Whirlpool KERC607EWH2
Whirlpool KERC607EWH4
Whirlpool KERC607EWH5
Whirlpool KERC607GAL0
Whirlpool KERC607GAL1
Whirlpool KERC607GBL0
Whirlpool KERC607GBL1
Whirlpool KERC607GBS0
Whirlpool KERC607GBS1
Whirlpool KERC607GBT0
Whirlpool KERC607GBT1
Whirlpool KERC607GWH0
Whirlpool KERC607GWH1
Whirlpool KERC607HBL0
Whirlpool KERC607HBL1
Whirlpool KERC607HBL10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HBL3
Whirlpool KERC607HBL4
Whirlpool KERC607HBL5
Whirlpool KERC607HBL6
Whirlpool KERC607HBL8
Whirlpool KERC607HBS0
Whirlpool KERC607HBS1
Whirlpool KERC607HBS10 30" Free - Standing Designer Style Convection Oven
Whirlpool KERC607HBS3
  #2 (permalink)
Old 07-20-2007, 01:31 AM
Admin / APP Team's Avatar
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
acillatem,
What about the surface elements? Do they work? If not, check the circuit breaker.
Assuming the circuit breakers are fine and your range is getting 220 volts (and not just 110 volts)... - I checked your model and don't see a fuse, however I do recall more than one case where KitchenAid forgot to include the fuse on the diagrams...
Try this: disconnect the power to the range first. Then, remove the back panel of the range. You should see the ends of all three oven elements. First, see if there is anything that looks like a fuse on the back wall of the range (small plastic component with two wires connected to it). If you don't see anything like that, you can trace the common wire and see where it leads to (there is a common wire that all three elements share). If there is no fuse (or thermostat), chances are it leads to the common relay on the board. This is where I would typically recommend replacing the board, but you've already done that. Let me know what you find. If you do see a fuse, get the 7 digit number off of it and post it here.
  #3 (permalink)
Old 07-20-2007, 07:41 AM
Junior Member
Default
Quote:
Originally Posted by Admin / APP Team View Post
acillatem,
Yes, everything else works just fine.........it's just the bottom oven that won't heat up on bake or broil. I'll check for fuse after work, and let you know......thanks!
  #4 (permalink)
Old 07-20-2007, 10:27 PM
Junior Member
Default
acillatem,
I have looked very thoroughly, and there is no fuse. Up in the top control panel all around the ERC board, and in the back after removing the back cover. I even followed the thick red wire down to the pigtail, and no fuse of any kind. I'm not kidding, it's not there, unless they hid it under the cooktop on mine, and I doubt that. I went and bought an Ohm Meter today, and checked all 3 elements, and all 3 registered zero when tested, which is what I should get if working correctly, right? And I checked the oven temperature sensor, and it measured 1000 ohms resistance, which I've been told is what it should be......hopefully that was accurate information. I did find the common wire that all 3 elements share, and it is a brown wire that ends up going to a sort of tan wire that ends up at some terminal on the ERC board, and the plastic over the connector has a kind of "burned" look to it, which seems odd to me. From what I can see, it still appears solid, so I'm assuming there is still a good connection, but this could be the problem, so I have a couple pictures, to see if anyone agrees, or has an idea what is going on with this. It is linked to the 3 elements, so maybe this is the culprit. Here are the 2 pictures:
http://i80.photobucket.com/albums/j1...6/DSCF1875.jpg
http://i80.photobucket.com/albums/j1...6/DSCF1874.jpg
Again, any advice greatly appreciated,and thanks in advance! I almost called the local repair place today after the new board didn't solve the problem,but I have this feeling it's something simple now. Sure hope so anyway. I don't give up easily lol.
  #5 (permalink)
Old 07-21-2007, 12:39 AM
Administrator
APP Team
Default
Looks good (read "bad") to me. Since you have a meter, go ahead and check that wire for continuity. Unplug it from the board, put one meter lead on each end and see if there is a break, probably at the terminal. But either way, that terminal looks pretty burnt up. I would recommend changing it. Radioshack should have one.
Let me know how it goes.
  #6 (permalink)
Old 07-21-2007, 01:12 AM
Junior Member
Default
So(since this is foreign to me), I pull that wire in the picture off, and then do I simply find the next break in that same wire, and then test it from those 2 ends??? Do I leave the meter on OHMs? I consider myself pretty handy, but electrical stuff is uncharted territory to me, for the most part, that's why I ask. What do you think caused that terminal to do that, and If I go to Radioshack, is there any special thing I need to ask for, or simply clip that terminal off, and say "i need one of these"? And thank you very much!
  #7 (permalink)
Old 07-21-2007, 12:36 PM
Administrator
APP Team
Default
acillatem,
After checking your photos again, I think you don't have to worry about testing the wire for continuity. Replace the terminal and that should do it. If you'd like to know how to test for continuity anyway, let me know.
What you need is a 1/4 inch female insulated terminal. Cut the old one off, leaving about half an inch of the wire on it. Take it to Radioshack. If you've never replaced a terminal before, the counter people should be able to show you how, and probably try to sell you wire strippers as well .
Keep us updated please. I'm curious to know what happens.
  #8 (permalink)
Old 07-21-2007, 02:01 PM
Junior Member
Default
acillatem,
Thanks again..........just got back from Radio Shack.....had to find it myself, the guy looked puzzled lol. Couldn't find a right angle one, but oh well, no big deal, straight will work. I've got crimpers and whatnot......I've done this kind of thing, so hopefully this is it. I would find it hard to believe that I would have bought a brand new board that would have a bad relay......anything is possible, but that would be pretty rare, I'm assuming.
  #9 (permalink)
Old 07-21-2007, 04:03 PM
Administrator
APP Team
Default
I agree, although possible, it's pretty rare for a new board to be defective. Of course if it is, you've got the warranty, and we'll take care of it right away.
Let me know what happens.
  #10 (permalink)
Old 07-21-2007, 04:42 PM
Junior Member
Default
O.k. the idiot sold me the wrong connectors, so I had to go back. I'll be doing all the testing and whatnot soon. The guy on the phone said electrical parts are not returnable, but you're saying it is under warranty?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
