Discuss
Kenmore: New control leaves 'extra" wire loose
 in
Kenmore 27" Electric Self-Clean, Double Wall Overn w/ERC Control and Motorized Door Lock - control quit working. Ordered two parts
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore: New control leaves 'extra" wire loose
  #1 (permalink)
Old 01-16-2008, 07:27 PM
Junior Member
zambojmc is on a distinguished road
Default Kenmore: New control leaves 'extra" wire loose
Model Number: 911. 48485   Brand: Kenmore   Age: 5 - 10 years
Kenmore 27" Electric Self-Clean, Double Wall Overn w/ERC Control and Motorized Door Lock - control quit working. Ordered two parts recommended here: AP3155969 (Manufacturer's Number: WB27T10282 made by GEH) and AP3425185 (Manufacturer's Number: WB36T10483 made by GEH) to replace.
Control looks much like the part it replaces, but with one major exception. The unit it replaces has a black wire (Labeled B-12 on original panel wiring schematic) which connects to a tab marked C and E4. There is no such tab identified as such on the new control.
I have matched up all other controls with the wiring harness, but have that one spare with no place to put it.
The diagram which accompanied the parts is poorly reproduced, and too small and fuzzy to read without a magnifying glass. I carefully read it under magnification to try to match connectors and then reproduced the drawing in a larger, color-coded version for my guidance.
When I started install however, I quickly ran into the problem of the "extra" wire and no tab on which to place it.
Please advise what I should do.
ADDED INFO:
Should have mentioned that there is no Convection component or wiring on this model.
Wound up with no Black L I wire for the BROIL 1 terminal. Is there a possibility that the "extra wire" connected to C E4 on the original panel can be used there?
My wiring diagram for new panel attached, with note of location of the missing C E4 tab to which the "extra" B - 12 terminal was attached.
http://mcphersonassociates.net/3858B...ol_diagram.gif
Ads By Google
Related Models
Kenmore 911.04698680  KENMORE ELECTRIC RANGE
Kenmore 911.04698690  KENMORE ELECTRIC RANGE
Kenmore 911.3202090  GAS COUNTER UNIT
Kenmore 911.3202091  30" GAS COUNTER UNIT
Kenmore 911.32080100  30" GAS COOKTOP
Kenmore 911.32085890  30" GAS COUNTER UNIT
Kenmore 911.32088890  30" GAS COUNTER UNIT
Kenmore 911.32089890  30" GAS COUNTER UNIT
Kenmore 911.3212590  30" GAS COUNTER UNIT
Kenmore 911.3212990  30" GAS COUNTER UNIT
Kenmore 911.32212100  COOKTOP
Kenmore 911.32212101  30" GAS COOKTOP
Kenmore 911.32214100  COOKTOP
Kenmore 911.32214101  30" GAS COOKTOP
Kenmore 911.32219100  COOKTOP
Kenmore 911.32219101  30" GAS COOKTOP
Kenmore 911.32222100  36" GAS COOKTOP
Kenmore 911.32222101  36" GAS COOKTOP
Kenmore 911.32224100  36" GAS COOKTOP
Kenmore 911.32224101  36" GAS COOKTOP
Kenmore 911.32229100  36" GAS COOKTOP
Kenmore 911.32229101  36" GAS COOKTOP
Kenmore 911.32255590  30" GAS COUNTER UNIT
Kenmore 911.32255591  30" GAS COUNTER UNIT
Kenmore 911.32255592  30" GAS COUNTER UNIT
Kenmore 911.32259590  30" GAS COUNTER UNIT
Kenmore 911.32259591  30" GAS COUNTER UNIT
Kenmore 911.32285890  30" GAS COUNTER UNIT
Kenmore 911.32289890  30" GAS COUNTER UNIT
Kenmore 911.32355590  30" GAS COUNTER UNIT
Kenmore 911.32355591  30" GAS COUNTER UNIT
Kenmore 911.32356590  30" GAS COUNTER UNIT
Kenmore 911.32356591  30" GAS COUNTER UNIT
Kenmore 911.32359590  30" GAS COUNTER UNIT
Kenmore 911.32359591  30" GAS COUNTER UNIT
Kenmore 911.32384101  30" GAS COOKTOP
Kenmore 911.32385100  30" GAS COOKTOP
Kenmore 911.32385890  30" GAS COUNTER UNIT
Kenmore 911.32386890  30" GAS COUNTER UNIT
Kenmore 911.32389100  30" GAS COOKTOP
Kenmore 911.32389890  30" GAS COUNTER UNIT
Kenmore 911.3522190  GAS RANGE
Kenmore 911.3524190  KENMORE - 30" DROP-IN RANGE
Kenmore 911.3528611  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 911.3528810  DROP IN GAS RANGE
Kenmore 911.3528812  DROP IN GAS RANGE
Kenmore 911.3542090  DROP-IN GAS RANGE
Kenmore 911.3544090  KENMORE 30" DROP-IN RANGE
Kenmore 911.3548691  KENMORE 30 INCH DROP-IN GAS RANGE
Kenmore 911.3548810  KENMORE GAS RANGE
Kenmore 911.3548813  DROP-IN GAS RANGE
Kenmore 911.3611190  GAS RANGE
Kenmore 911.3618810  KENMORE 30 IN GAS RANGE
Kenmore 911.3618811  GAS RANGE
Kenmore 911.3618890  KENMORE 30 IN GAS RANGE
Kenmore 911.3628610  KENMORE GAS RANGE
Kenmore 911.3628611  KENMORE GAS RANGE
Kenmore 911.3628690  KENMORE GAS RANGE
Kenmore 911.3628710  KENMORE GAS RANGE
Kenmore 911.3631990  GAS RANGE
Kenmore 911.3632090  SLIDE-IN RANGE
Kenmore 911.3638611  KENMORE GAS RANGE
Kenmore 911.3638690  KENMORE GAS RANGE
Kenmore 911.3638710  KENMORE GAS RANGE
Kenmore 911.3638810  KENMORE GAS RANGE
Kenmore 911.3638811  30" GAS RANGE
Kenmore 911.3638812  GAS RANGE
Kenmore 911.3651190  Slide-In Range, Gas
Kenmore 911.3652090  GAS RANGE
Kenmore 911.3652091  GAS RANGE
Kenmore 911.3652190  GAS RANGE
Kenmore 911.3652191  GAS RANGE
Kenmore 911.3654090  30" SELF-CLEANING OVEN
Kenmore 911.3654190  KENMORE 30" GAS SELF-CLEAN RANGE
Kenmore 911.3654191  30" SELF-CLEANING OVEN
Kenmore 911.3658610  KENMORE GAS RANGE
Kenmore 911.3658611  KENMORE GAS RANGE
Kenmore 911.3658690  KENMORE GAS RANGE
Kenmore 911.3658691  KENMORE GAS RANGE
Kenmore 911.3658790  KENMORE GAS RANGE
Kenmore 911.3658812  GAS RANGE
Kenmore 911.36655591  30" GAS SLIDE-IN RANGE
Kenmore 911.36655792  30" GAS SLIDE-IN RANGE
Kenmore 911.36655793  30" GAS SLIDE-IN RANGE
Kenmore 911.36655794  30" GAS SLIDE-IN RANGE
Kenmore 911.36655795  30" GAS SLIDE-IN RANGE
Kenmore 911.36659791  30" GAS SLIDE-IN RANGE
Kenmore 911.36659792  30" GAS SLIDE-IN RANGE
Kenmore 911.3672590  30" SLIDE-IN GAS RANGE
Kenmore 911.3672591  GAS SLIDE-IN RANGE
Kenmore 911.3672990  30" SLIDE-IN GAS RANGE
Kenmore 911.3672991  GAS SLIDE-IN RANGE
Kenmore 911.3678855  GAS RANGE
Kenmore 911.3678856  GAS RANGE
Kenmore 911.3678857  GAS RANGE
Kenmore 911.3678895  GAS RANGE
Kenmore 911.3678896  GAS RANGE
Kenmore 911.4229290  ELECTRIC COOKTOP
Kenmore 911.4242090  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242091  ELECTRIC COUNTER UNIT
Kenmore 911.4242092  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242190  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242191  ELECTRIC COUNTER UNIT
Kenmore 911.4242192  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242590  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242591  ELECTRIC COUNTER UNIT
Kenmore 911.4242592  30" ELECTRIC COUNTER UNIT
Kenmore 911.4242791  30" ELECTRIC COUNTER UNIT
Kenmore 911.42455590  30" ELECTRIC COUNTER UNIT
Kenmore 911.42456590  30" ELECTRIC COUNTER UNIT
Kenmore 911.42459590  30" ELECTRIC COUNTER UNIT
Kenmore 911.42474100  30" COUNTER UNIT
Kenmore 911.42475890  30" COUNTER UNIT
Kenmore 911.42476890  30" COUNTER UNIT
Kenmore 911.42479890  30" COUNTER UNIT
Kenmore 911.4252590  ELECTRIC COUNTER UNIT
Kenmore 911.4252990  ELECTRIC COUNTER UNIT
Kenmore 911.42612100  30" RADIANT COUNTER UNIT
Kenmore 911.42617100  30" RADIANT COUNTER UNIT
Kenmore 911.42619100  30" RADIANT COUNTER UNIT
Last edited by zambojmc : 01-16-2008 at 10:47 PM. Reason: Additional Information and diagram
  #2 (permalink)
Old 01-17-2008, 02:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I believe the black wire you are talking about (labeled B-12) and originally connected to the "C" terminal on the old control board is in L1 circuit and should be connected to either COM0 or COM1 terminals on the new control board.
It suppose to be 4 black wires, providing L1 power.
They should be connected to: the COM terminal on the BROIL1 relay, the COM terminal on the BROIL2 relay, the COM0 terminal on the right side and the COM1 terminal at the same place.
Check all these wires for continuity across each other.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-17-2008, 03:11 PM
Junior Member
Thumbs up Thanks ...
I was hoping that would be the case, and greatly appreciate your help.
At the cost of those control boards, you sure don't want to fry one.
My wife thanks you, also! The best of luck to you and yours.
zambojmc
  #4 (permalink)
Old 01-05-2010, 08:40 PM
Junior Member
lkljunky is on a distinguished road
Default I had the same problem with the instructions...
I had the same problem with the instructions thanks for the confirmation of where to connect the remaining wire. I do have a follow up question, after i used to oven 3 times I'm now getting the F0 error again. I'm thinking of replacing the keypad this time. Does this sound like the next thing I should do?. If so does the keypad assembly come with the control unit? I can still return the control unit if it does and just get the keypad assembly in return. For some background information i did the recommended test to check if the keypad was the problem or the ERC and the ERC came out as the fault. I got and installed the replacement control panel part# WB27T10282. Thanks for any help.
  #5 (permalink)
Old 01-08-2010, 01:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by lkljunky View Post
...i did the recommended test to check if the keypad was the problem or the ERC and the ERC came out as the fault...
Before replacing the key pad I would do this test again because possible the new ERC is defective.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Loose ground wire under top tomb215 Oven Repair (including Ranges and Cooktops) 0 02-04-2010 09:37 AM
Loose wire Turnberry Dryer Repair 2 12-04-2009 08:06 AM
Freezer: after defrost, water drips, then leaves frozen "ice drops" Troubleshooter Refrigerator & Freezer Repair 3 04-03-2009 12:23 PM
Water line "sprung" loose = FLOOD jshoe01 Refrigerator & Freezer Repair 3 01-31-2008 07:41 PM
dishwasher leaves "sand" on the dishes!!! pamelalsimmons Dishwasher Repair 0 01-23-2008 08:42 AM
