| » Jenn Air Cooktop Gas Range |
Model Number: JGC1536ADS Brand: Jenn-Air Age: 1 - 5 years
none of the four gas buners are igniting. I have to use a match to get burners started. also, vent and light hood works when the electrical plug is unplugged. help. Thank you.
Hello.
First check if there 120v at the power plug. If you have 120v at the appliance outlet, take the top off and check power cord and wires. Next with voltmeter set on Volts AC turn the burner on and check for 120v at the spark module leads L - N. With 120v present, replace the spark module. The spark module Part number: AP4094158 If there is voltage at module, you have 4 bad spark switches (very small chance). The spark switch Part number: AP4433921 Here are the breakdown diagrams and Replacement parts for Jenn-Air JGC1536ADS GAS COOKTOP | AppliancePartsPros.com Good luck. Post the results.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| jenn air cooktop | mjshur | Oven Repair (including Ranges and Cooktops) | 1 | 03-12-2012 06:18 PM |
| Jenn-Air Cooktop | A. Scott | Oven Repair (including Ranges and Cooktops) | 0 | 09-10-2011 10:55 AM |
| Jenn Air Cooktop | Joepa7 | Oven Repair (including Ranges and Cooktops) | 0 | 04-11-2011 01:08 PM |
| Old Jenn-Air Cooktop | fredringwald | Oven Repair (including Ranges and Cooktops) | 3 | 06-19-2009 03:04 PM |
| Jenn air range glass cooktop replacement | santostefano | Oven Repair (including Ranges and Cooktops) | 1 | 04-22-2009 01:40 PM |
