Discuss
GE Profile center burner slow light/low gas
 in
I have a GE Prfoile stove. The center burner (large oblong under the hot plate) exhibits a problem. When I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Profile center burner slow light/low gas
  #1 (permalink)
Old 03-25-2012, 10:01 AM
Junior Member
pessemist is on a distinguished road
Default GE Profile center burner slow light/low gas
Brand: GE   Age: 1 - 5 years
I have a GE Prfoile stove. The center burner (large oblong under the hot plate) exhibits a problem. When I turn it on only a few holes near the igniter will light with flame.
The flame level is very low. I can light parts of the rest of the burner with a match but, again, the flame is very low.
I thought maybe the burner top holes were clogged and I washed and poked each hole with a wire. They are open. I also put the wire down the center of the gas jet under the burner and there doesn't seem to be any restriction there.
It seems like there is too little gas coming out despite having the knob turned to 'High".
Any suggestions as to what the problem could be
Thanks all!
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 4 01-30-2011 08:26 PM
replacing ignitor on center burner tom.orourke Oven Repair (including Ranges and Cooktops) 0 11-08-2010 10:09 AM
Stovetop Center Burner won't stay lit Jhrusovszky Oven Repair (including Ranges and Cooktops) 0 11-06-2010 02:49 PM
Center element of dual surface burner stays on! kent123 Oven Repair (including Ranges and Cooktops) 3 04-27-2010 04:01 PM
Frigidaire Laundry Center Slow Spin txtechnot Washer Repair 1 09-23-2009 08:34 AM
