Hello. I need to replace the outer glass on the lower oven door because I broke it. I was told by a representative that I need Part Number: AP3837648
However, before I order, I need to know how to get to the glass. I removed all the screws that I can see (door is still attached) and the front part isn't budging. There appears to be two brackets on the inside that i guess holds on the handle. I can get to two of the screws there but there are two more that I can't get to. Do I need to take the oven door off to do this repair? I am at a complete loss and incredibly frustrated.
Any help would be greatly appreciated.
Thank you.
Frank
THIS FORUM IS DEAD!!!!!!! |
