| » KitchenAid Oven ERC? |
Model Number: KEBS107DBS7 Brand: Kitchen Aid Age: More than 10 years
Folks,
Our oven just died with an F1E7 error. I think that is the electronic range control (ERC)? The oven is approx 13 years old and think we should probably replace the probe sensor in back of oven as well. Looking for part numbers, schematics and advise/ direction on changing it out. thanks for any assistance! Good bless! Ads By Google Related Models |
HI, Lance.
You are right - the F1E7 means bad ERC. The ERC Part number: AP3135399 Here are the step by step: - disconnect the power - open oven door - remove the bottom screw from each side of the trim - pull trim's bottom out and down - remove screws from each side of the oven control panel - pull panel out at the bottom and lift - disconnect the wire connectors - remove 5 screws holding the control board - lift the ends of the locking arm and disconnect the ribbon cable. Handle the new control carefully it's sensitive to electro static discharge. The temperature sensor Part number: AP3008972 Her are the breakdown diagrams and Replacement parts for Whirlpool KEBS107DBS7 30" BUILT-IN ELECTRIC WALL OVEN | AppliancePartsPros.com Thank you. Post the results.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| kitchenaid oven | ron murphy | Oven Repair (including Ranges and Cooktops) | 1 | 09-07-2011 09:03 PM |
| KitchenAid Oven not maintaining Oven Temp | Jane D | Oven Repair (including Ranges and Cooktops) | 3 | 09-28-2010 02:54 PM |
| kitchenaid oven | malvert | Oven Repair (including Ranges and Cooktops) | 0 | 08-19-2009 06:12 PM |
| Kitchenaid Oven | buenrico3 | Oven Repair (including Ranges and Cooktops) | 0 | 04-28-2009 08:36 AM |
