Discuss
Oven temperature discrepancy
 in
1994 Magic Chef 6498VTA oven temp 175 degrees below setpoint as indicated by oven thermometer touchpad digitally indicates that temp
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven temperature discrepancy
  #1 (permalink)
Old 08-17-2009, 05:08 PM
Junior Member
killermrob83 is on a distinguished road
Default Oven temperature discrepancy
Model Number: 6498VTA   Brand: Magic Chef   Age: More than 10 years
touchpad digitally indicates that temp is rising normally until desired setpoint is reached, then beeps to indicate such, no fault codes or other issues at hand
oven temp sensor ohms out at 1143 ohms @ 80 degrees
I believe touchpad to be defective, but would apprecite your professional advice
unit is in immaculate condition, touchpad has been replaced 3 times previously because it would beep at various times throughout the day/night when oven not in use and no fault codes displayed, each time the unit worked properly until again failed
Thank you for your time and consideration
Ads By Google
Related Models
Magic Chef 6498VTA RANGE- S/C S/I GAS
Magic Chef 6498VTV RANGE- S/C S/I GAS
Magic Chef 6498VVA GAS RANGE
Magic Chef 6498VVD RANGE- S/C S/I GAS
Magic Chef 6498VVV RANGE- S/C S/I GAS
Magic Chef 6498XRA RANGE- S/C S/I GAS
Magic Chef 6498XRS RANGE- S/C S/I GAS
Magic Chef 6498XRW RANGE- S/C S/I GAS
Magic Chef 6498XTA RANGE- S/C S/I GAS
Magic Chef 6498XTS RANGE- S/C S/I GAS
Magic Chef 6498XTW RANGE- S/C S/I GAS
Magic Chef 6498XVB RANGE- S/C S/I GAS
Magic Chef 6498XVS RANGE- S/C S/I GAS
Magic Chef 64EA-3CKW RANGE- S/C S/I GAS
Magic Chef 64EB-3CKW RANGE- S/C S/I GAS
Magic Chef 64EN-3CKW RANGE- S/C S/I GAS
Magic Chef 64EY-3CKW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKVW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKW RANGE- S/C S/I GAS
Magic Chef 64FA-3CKX RANGE- S/C S/I GAS
Magic Chef 64FA-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FB-3CKW RANGE- S/C S/I GAS
Magic Chef 64FK-3CKX RANGE- S/C S/I GAS
Magic Chef 64FK-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKVW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKW RANGE- S/C S/I GAS
Magic Chef 64FN-3CKX RANGE- S/C S/I GAS
Magic Chef 64FN-3CKXW RANGE- S/C S/I GAS
Magic Chef 64FY-3CKW RANGE- S/C S/I GAS
Magic Chef 64FY-3CKX RANGE- S/C S/I GAS
Magic Chef 64FY-3CKXW RANGE- S/C S/I GAS
Magic Chef 64H-4TKVW RANGE- S/C S/I GAS
Magic Chef 64H-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HA-4TKVW RANGE- S/C S/I GAS
Magic Chef 64HA-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HK-4TKXW RANGE- S/C S/I GAS
Magic Chef 64HN-4TKVW RANGE- S/C S/I GAS
Magic Chef 64HN-4TKXW RANGE- S/C S/I GAS
Hoover 65
Amana 650.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 650.001 RANGE- S/C S/I DDRAFT GAS
Magic Chef 6500PRA RANGE- S/I STD ELE
Magic Chef 6500PRW RANGE- S/I STD ELE
Magic Chef 6500SRS RANGE- S/I STD ELE
Frigidaire 6504A WASHER
Frigidaire 6504B WASHER
Frigidaire 6504C WASHER
Frigidaire 6504D WASHER
Frigidaire 6504E WASHER
Frigidaire 6504E-87 WASHER
Frigidaire 6505A WASHER
Frigidaire 6505B WASHER
Frigidaire 6505C WASHER
Frigidaire 6506-87A WASHER
Frigidaire 6506-87C WASHER
Frigidaire 6506-87D TOP LOAD WASHER
Frigidaire 6506-87E TOP LOAD WASHER
Frigidaire 6506A WASHER
Frigidaire 6506B WASHER
Frigidaire 6507-87A WASHER
Frigidaire 6507-87C WASHER
Frigidaire 6507-87D WASHER
Frigidaire 6507-87E TOP LOAD WASHER
Frigidaire 6507A WASHER
Frigidaire 6508D WASHER
Hoover 651
Amana 651.000 RANGE- S/C S/I DDRAFT GAS
Amana 651.001 RANGE- S/C S/I DDRAFT GAS
Amana 651.002 RANGE- S/C S/I DDRAFT GAS
Amana 651.003 RANGE- S/C S/I DDRAFT GAS
Amana 651.004 RANGE- S/C S/I DDRAFT GAS
Amana 651.006 RANGE- S/C S/I DDRAFT GAS
Kenmore 65189918100 WRINGER WASHER
Admiral 651AH RANGE- S/C F/S ELE
Admiral 651WH RANGE- S/C F/S ELE
Admiral 653AH-HV RANGE- F/S STD ELE
Admiral 653AH-V RANGE- F/S STD ELE
Admiral 653AJ-HV RANGE- F/S STD ELE
Admiral 653AJ-V RANGE- S/C F/S ELE
Admiral 653AJ-V-CX RANGE- F/S STD ELE
Admiral 653WH-HV RANGE- F/S STD ELE
Admiral 653WH-V RANGE- F/S STD ELE
Admiral 653WJ-HV RANGE- F/S STD ELE
Admiral 653WJ-V RANGE- S/C F/S ELE
Admiral 653WJ-V-CX RANGE- F/S STD ELE
Admiral 654AD-HVW RANGE- F/S STD ELE
Admiral 654AG-HVW RANGE- F/S STD ELE
Admiral 654AH-ELVW RANGE- F/S CONT CLEAN ELE
Admiral 654AH-EVW RANGE- F/S STD ELE
Admiral 654AH-EW RANGE- F/S STD ELE
Admiral 654WD-HVW RANGE- F/S STD ELE
Admiral 654WG-HVW RANGE- F/S STD ELE
Admiral 654WH-ELVW RANGE- F/S CONT CLEAN ELE
Admiral 654WH-ELW RANGE- F/S CONT CLEAN ELE
Admiral 654WH-EW RANGE- F/S STD ELE
Magic Chef 6551WRA RANGE- S/I STD ELE
Magic Chef 6551WRW RANGE- S/I STD ELE
Magic Chef 6551WUA RANGE- S/I STD ELE
Magic Chef 6551WUB RANGE- S/I STD ELE
Magic Chef 6551WUW RANGE- S/I STD ELE
Magic Chef 6551XRA RANGE- S/I STD ELE
Magic Chef 6551XRW RANGE- S/I STD ELE
Magic Chef 6551XUA RANGE- S/I STD ELE
Magic Chef 6551XUB RANGE- S/I STD ELE
Magic Chef 6551XUW RANGE- S/I STD ELE
Admiral 655AH-CVW RANGE- F/S STD ELE
Admiral 655WH-CVW RANGE- F/S STD ELE
Admiral 656AH-EHVW RANGE- F/S STD ELE
Admiral 656HH-EHVW RANGE- F/S STD ELE
Admiral 656WH-EHVW RANGE- F/S STD ELE
Frigidaire 6589-80 WASHER
Frigidaire 6589-80B WASHER
Frigidaire 6589-87 WASHER
Maytag 65C DRYER- GAS
Magic Chef 65HA-1 RANGE- S/I STD ELE
Magic Chef 65HA-3W RANGE- S/I STD ELE
Magic Chef 65HA-3X RANGE- S/I STD ELE
Magic Chef 65HN-1 RANGE- S/I STD ELE
Magic Chef 65HN-3W RANGE- S/I STD ELE
Magic Chef 65HN-3X RANGE- S/I STD ELE
  #2 (permalink)
Old 09-03-2009, 07:44 AM
Junior Member
Default not the touchpad
Upon further investigation into the problem, I have discovered that the problem does not lie in the membrane switch. The only other parts that could be the problem are 7428P010-60 (relay board) or 7601P206-60 (cntrl-elec). Any ideas?
  #3 (permalink)
Old 09-03-2009, 10:03 PM
Junior Member
fixyourboard is on a distinguished road
Default
Based on your description of the symptoms I would say that about 21 degrees of the discrepancy is due to your temperature sensor (should read 1100 ohms @ 80 F). The rest of the error is likely due to a problem with the controller ( 7601P206-60 ). This is a fairly common failure in the controller.
Bruce
  #4 (permalink)
Old 09-21-2009, 04:01 PM
Junior Member
Default assistance needed with additional problem
Quote:
Bruce
Thank you so much with your diagnosis, but another problem has just occurred..............the auto ignition has stopped functioning for the stove top. Would I be fortunate enough for the same controller that is causing the oven problem to be this issue in this case, also? Thanks again Rob
  #5 (permalink)
Old 09-22-2009, 04:49 PM
Junior Member
Default
I think it's not likely to be the controller, more likely a worn out ignitor.
  #6 (permalink)
Old 09-23-2009, 07:40 AM
Junior Member
Default thank you
Thank you, I have ordered a spark module (igniter) and that should take care of the problem. While searching for info I found a place in Windsor, Ontario that rebuilds clock timers for half the cost of a new one and they give a 1 year warranty. If anyone wants that info I can get it for you. Because it's my aunts stove, I bought her a new one from Midwest in Chigago,IL for 179.99.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Oven temperature Bad jeffdroy Oven Repair (including Ranges and Cooktops) 1 12-22-2009 11:01 PM
Oven will not keep temperature daholloway Oven Repair (including Ranges and Cooktops) 1 12-18-2009 02:40 AM
Oven temperature nada Oven Repair (including Ranges and Cooktops) 0 09-12-2009 11:43 AM
Cannot set temperature on oven ksnyde01 Oven Repair (including Ranges and Cooktops) 2 01-22-2009 06:42 PM
Oven Temperature Low schredder Oven Repair (including Ranges and Cooktops) 1 09-30-2008 01:51 PM
