I have two issues.
a. The control panel display on my stove went blank, however I am able to key in temperatures (feedback of entry via beeps) to start the oven. Is there a fuse I can change to get the display back on?
b. The cook top igniters (spark) on all the burners stopped working over a period of 6 months. I have to manually light the flame using a match stick. Where do I start i.e. should I check the spark module?
Any help is greatly appreciated.
Problem Solved.
Replaced the Igniter switches, and the display control board and that seemed to have solved the problem :)
