I have a magic chef model # 3127wtv gas oven. The oven itself (not the burners) is not getting hot. My guess would be that it is the ignitor? I just want to verify that it does not have a pilot. I do not see any indication there is. Plus the cook top has electronic ignition. May be a stupid question considering the cooktop has electronis ignition, but figured I would ask anyway. Also it does not appear to be a regulator issue, I do smell gas. Thanks for any feed back!
Originally Posted by: rick 77 I have a magic chef model # 3127wtv gas oven. The oven itself (not the burners) is not getting hot. My guess would be that it is the ignitor? I just want to verify that it does not have a pilot. I do not see any indication there is. Plus the cook top has electronic ignition. May be a stupid question considering the cooktop has electronis ignition, but figured I would ask anyway. Also it does not appear to be a regulator issue, I do smell gas. Thanks for any feed back! There is a ignitor. It will be located under the oven bottom. If you have voltage to it and it's not glowing then it is bad. You may also see that it's visually broken. Below is what the igitor looks like, along with the part #. Part number: AP4012072
