| » Tsting a Tappen Oven lower element |
Model Number: 11 1969 10/05 Brand: Tappan Age: 5 - 10 years
My lower element appears to be burnt out.
Can a test be done to confirm? Ads By Google Related Models |
TURN POWER OFF TO OVEN BEFORE DOING ANY TESTING. Remove element from oven and disconnect wires form element. Using an OHM meter you test the element for continuity. Take the meter leads and touch them to the terminals where the two wires would go. Easiest terminology...if there is no movement on the meter whether digital or analog, the element is open and would need replacing. If you get movement or if the meter shows an infinte reading chances are the element is ok and you will have to start looking else where for problems.
| Display Modes | |
| Whirlpool Oven Lower Element Melted Down | katzandmice | Oven Repair (including Ranges and Cooktops) | 2 | 01-31-2010 08:14 AM |
| lower oven heating element does not get hot | rbotthof | Oven Repair (including Ranges and Cooktops) | 1 | 11-22-2009 11:15 AM |
| Lower oven heating element | Blake Powell | Oven Repair (including Ranges and Cooktops) | 0 | 10-15-2009 09:30 PM |
| lower oven element problem | jjj | Oven Repair (including Ranges and Cooktops) | 0 | 02-16-2008 08:05 AM |
| Lower oven heating element | Joeknight | Oven Repair (including Ranges and Cooktops) | 1 | 12-21-2007 07:25 AM |
