Discuss
Oven will not heat
 in
Upper oven will not heat - Bake or Broil. Lower oven works fine. Ads By Google Related Models Thermador  MSC29
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat
  #1 (permalink)
Old 01-15-2008, 03:54 PM
Junior Member
double door thermador is on a distinguished road
Default Oven will not heat
Model Number: MSC28-2   Brand: Thermador   Age: More than 10 years
Ads By Google
Related Models
Thermador MSC29
Thermador MSC2BG-SD
Thermador MSC39
Maytag MSD2142ARW Ref - SXS/I&W
Maytag MSD2143ARW Ref - SXS/I&W
Whirlpool MSD2258KES00 Refrigerator
Maytag MSD2258KES00 Refrigerator
Whirlpool MSD2258KES01 Refrigerator
Maytag MSD2258KES01 Refrigerator
Whirlpool MSD2258KEU00 Refrigerator
Maytag MSD2258KEU00 Refrigerator
Whirlpool MSD2258KEU01 Refrigerator
Maytag MSD2258KEU01 Refrigerator
Whirlpool MSD2258KGB00 Refrigerator
Maytag MSD2258KGB00 Refrigerator
Whirlpool MSD2258KGB01 Refrigerator
Maytag MSD2258KGB01 Refrigerator
Whirlpool MSD2258KGW00 Refrigerator
Maytag MSD2258KGW00 Refrigerator
Whirlpool MSD2258KGW01 Refrigerator
Maytag MSD2258KGW01 Refrigerator
Whirlpool MSD2269KEA00 Refrigerator
Maytag MSD2269KEA00 Refrigerator
Whirlpool MSD2269KEA01 Refrigerator
Maytag MSD2269KEA01 Refrigerator
Whirlpool MSD2269KEB00 Refrigerator
Maytag MSD2269KEB00 Refrigerator
Whirlpool MSD2269KEB01 Refrigerator
Maytag MSD2269KEB01 Refrigerator
Whirlpool MSD2269KEW00 Refrigerator
Maytag MSD2269KEW00 Refrigerator
Whirlpool MSD2269KEW01 Refrigerator
Maytag MSD2269KEW01 Refrigerator
Whirlpool MSD2269KEY00 Refrigerator
Maytag MSD2269KEY00 Refrigerator
Whirlpool MSD2269KEY01 Refrigerator
Maytag MSD2269KEY01 Refrigerator
Maytag MSD2343ARA Ref - SXS/I&W
Maytag MSD2343ARQ Ref - SXS/I&W
Maytag MSD2343ARW Ref - SXS/I&W
Maytag MSD2351HEB Ref - SXS/I&W
Maytag MSD2351HEQ Ref - SXS/I&W
Maytag MSD2351HES Ref - SXS/I&W
Maytag MSD2351HEW Ref - SXS/I&W
Maytag MSD2351KES Ref - SXS/I&W
Maytag MSD2352KEB Ref - SXS/I&W
Maytag MSD2352KES Ref - SXS/I&W
Maytag MSD2352KEW Ref - SXS/I&W
Maytag MSD2354ARA Ref - SXS/I&W
Maytag MSD2354ARW Ref - SXS/I&W
Maytag MSD2354DRA Ref - SXS/I&W
Maytag MSD2354DRW Ref - SXS/I&W
Maytag MSD2354FRA Ref - SXS/I&W
Maytag MSD2354FRW Ref - SXS/I&W
Maytag MSD2355HEB Ref - SXS/I&W
Maytag MSD2355HEQ Ref - SXS/I&W
Maytag MSD2355HES Ref - SXS/I&W
Maytag MSD2355HEW Ref - SXS/I&W
Maytag MSD2356AEA Ref - SXS/I&W
Maytag MSD2356AEB Ref - SXS/I&W
Maytag MSD2356AEW Ref - SXS/I&W
Maytag MSD2357HEB Ref - SXS/I&W
Maytag MSD2357HEQ Ref - SXS/I&W
Maytag MSD2357HES Ref - SXS/I&W
Maytag MSD2357HEW Ref - SXS/I&W
Maytag MSD2359KEB Ref - SXS/I&W
Maytag MSD2359KEQ Ref - SXS/I&W
Maytag MSD2359KES Ref - SXS/I&W
Maytag MSD2359KEW Ref - SXS/I&W
Maytag MSD2422GRQ Ref - SXS/I&W
Maytag MSD2422GRW Ref - SXS/I&W
Maytag MSD2432GRQ Ref - SXS/I&W
Maytag MSD2432GRW Ref - SXS/I&W
Maytag MSD2433HEW Ref - SXS/I&W
Maytag MSD2434GEQ Ref - SXS/I&W
Maytag MSD2434GEW Ref - SXS/I&W
Maytag MSD2436GRQ Ref - SXS/I&W
Maytag MSD2436GRW Ref - SXS/I&W
Maytag MSD2445GRQ Ref - SXS/I&W
Maytag MSD2445GRW Ref - SXS/I&W
Maytag MSD2448DRQ Ref - SXS/I&W
Maytag MSD2448DRW Ref - SXS/I&W
Maytag MSD2454FRQ Ref - SXS/I&W
Maytag MSD2454FRW Ref - SXS/I&W
Maytag MSD2454GRQ Ref - SXS/I&W
Maytag MSD2454GRW Ref - SXS/I&W
Maytag MSD2456DEB Ref - SXS/I&W
Maytag MSD2456DEQ Ref - SXS/I&W
Maytag MSD2456DEW Ref - SXS/I&W
Maytag MSD2456GEB Ref - SXS/I&W
Maytag MSD2456GEQ Ref - SXS/I&W
Maytag MSD2456GEW Ref - SXS/I&W
Maytag MSD2458GEB Ref - SXS/I&W
Maytag MSD2458GEQ Ref - SXS/I&W
Maytag MSD2458GEW Ref - SXS/I&W
Maytag MSD2543ARA Ref - SXS/I&W
Maytag MSD2543ARW Ref - SXS/I&W
Maytag MSD2554ARA Ref - SXS/I&W
Maytag MSD2554ARW Ref - SXS/I&W
Maytag MSD2554DRA Ref - SXS/I&W
Maytag MSD2554DRW Ref - SXS/I&W
Maytag MSD2554FRA Ref - SXS/I&W
Maytag MSD2554FRW Ref - SXS/I&W
Maytag MSD2555DRA Ref - SXS/I&W
Maytag MSD2555DRW Ref - SXS/I&W
Maytag MSD2556AEA Ref - SXS/I&W
Maytag MSD2556AEB Ref - SXS/I&W
Maytag MSD2556AEW Ref - SXS/I&W
Maytag MSD2641KEB Ref - SXS/I&W
Maytag MSD2641KES Ref - SXS/I&W
Maytag MSD2641KEU Ref - SXS/I&W
Maytag MSD2641KEW Ref - SXS/I&W
Maytag MSD264RHEB Ref - SXS/I&W
Maytag MSD264RHEQ Ref - SXS/I&W
Maytag MSD264RHES Ref - SXS/I&W
Maytag MSD264RHEW Ref - SXS/I&W
Maytag MSD2650HEB Ref - SXS/I&W
Maytag MSD2650HEQ Ref - SXS/I&W
Maytag MSD2650HES Ref - SXS/I&W
Maytag MSD2650HEW Ref - SXS/I&W
  #2 (permalink)
Old 01-16-2008, 01:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the hi temperature cut out is "off". It is resettable and located on the back of the oven.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-16-2008, 01:12 PM
Junior Member
Default
Gene,
Thank you for your reply and suggestion. I will remove the oven from the wall and reset the "hi temp cut off" on the back of the oven. Hopefully it is easily identifiable. I will let you know what heppens. Thanks!
  #4 (permalink)
Old 01-20-2008, 09:52 AM
Junior Member
Default
I have removed the oven from the wall. I cannot locate a hi temperature cut out to reset. The only wires/items on the back of the oven are the wiring and connection points to the heat elements, the interior oven lights and the interior oven thermostats.
I did check the voltage coming to the elements and found the red wire for the broiler element and the black wire for the bake element both of which are connected tot he left side of the selector switch do produce 120 volts. Whereas the Blue wire that jumps to the bake and broil element that is connectected to the right side of the selector switch only produces about 60 volts. My understanding is that both leads should produce 120 volts.
I also noticed that when the selector switch is on Bake, both the red lead to the broil element and the black lead to the bake element produce 120 volts. Whereas when the selector switch is on broil the red wire connected to the broil element produces 120 volts and the black wire connecting to the bake element produces 14-15 volts. I assume this is normal in that when baking, the broil element may come on for a short period of time in order to quickly pre heat the oven to the disired bake temperature.
Please Advise.
  #5 (permalink)
Old 01-20-2008, 10:02 AM
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
take both leads off of the bake element... ( MAKE SURE YOU DO NOT ALLOW EITHER OF THEM TO TOUCH CHASSIS !!!) CHECK each wire to ground to see which is HOT ( or has 120vac .. ) then turn power off and the wire that is not HOT ( doesn't have 120vac ) follow back to point of origin ( could be to a non-resettable safety t-stat, but could also be to the push button switch , which by the way, i think is NLA ) but it could also be to the HOT WIRE RELAY ....
__________________
regards
jim
  #6 (permalink)
Old 01-20-2008, 10:38 AM
Junior Member
Default
Kawfeeman,
I have done as suggested. The hot wire, or the wire that does not produce 120 volts, rather 48-60 volts, connects directly to the selector switch at the front of the oven. (along with about 30 other wires) part number 14-19-19-198. I do not see a reset button or switch on that part.
  #7 (permalink)
Old 01-20-2008, 10:46 AM
Senior Expert
APP Volunteer
Default
there is not a reset for the selector switch .. ( the other wire definitely does have 120vac ) ?
__________________
regards
jim
  #8 (permalink)
Old 01-20-2008, 10:52 AM
Junior Member
Default
No reset for the selecor switch that I can see. The other lead definately has 120 volts. In fact, the 120 volt producing lead comes form the other side of the selector switch.
  #9 (permalink)
Old 01-20-2008, 12:18 PM
Senior Expert
APP Volunteer
Default
have you made certain that the wire is not bad ???
__________________
regards
jim
  #10 (permalink)
Old 01-20-2008, 12:33 PM
Junior Member
Default
Yes, I can test the voltage/source at the selector switch, eliminating the wire question.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
Oven broiler and burners work - oven will not heat fatbuford Oven Repair (including Ranges and Cooktops) 0 11-27-2009 05:50 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 09:14 AM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 09:56 AM
