My Stove Igniter Does Not Work On My Gas Stove. Thanks Jack
My Stove Igniter Does Not Work On My Gas Stove. THE AUTOMATIC IGNITER DOES NOT FUNCTION ON 2 OF THE STOVES BURNERS ,THE OTHER 2 IS JUST FINE. Thanks Jack
Groups: APP Team
Hi, Jack.
I need more info, please.When you turn the knobs one by one how many ignitors spark? When you turn on the burners in question is the other spark?
Please, post the answer.
2 of the burners on the right works well .with one spark and there on.The 2 on the left side you turn on there is no sparks but gas is flowing. So 2 right ones are working 2 left ones are not working . thanks JACK
Groups: APP Team
Hello. Most likely the problem is with igniter switches. Take the top off (you need to take all burners out and lift the top) and switch around good one with one in question. If it will work - you need two switches. If it wont- replace the spark module. The igniter switch Part number: AP3191247
