Hi wanted to know if you could help...i have a maytag CSG6000AAW and the left side clicks and then a fast spark to ignite; however the right side and the middle just click but do not ignite and no spark.-I can light it with a match or lighter though. Please advise me on what I should to to fix this. Thank you in advance.
Hi wanted to know if you could help...i have a maytag CSG6000AAW and the right side clicks and ignites; however the left side and the middle just click but do not ignite. I can light it with a match or lighter though. Please advise me on what I should to to fix this. Thank you in advance.
Very likely the problem is a bad spark module (#7 at the diagram). It comes with the installation instructions. - The spark module Part number: AP4010034
Hi Gene, I am not sure that this is the correct part. It has 4 prongs on top and mine has 6. Please advise on this as soon as you can. Thanks and blessings! Oh one more thing...WHen repairing this do I have to turn off the power? Originally Posted by: Gene Very likely the problem is a bad spark module (#7 at the diagram). It comes with the installation instructions. - The spark module Part number: AP4010034
This part has been redesigned by the manufacturer. As you can see at the diagram, there are five burners but only three igniter. So you really going to use only three spark module output terminals. It does not make any difference which terminal is connected to which igniter. An unused terminal must be connected to the ground. Gene.
Hi again Gene Just wanted to say thanx for all your help. Turns out it was the right pArt afterall. Got it! Thanx again!
You are welcome. I'm glad you were able to fix it.
