Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   f10 error code (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html)
lindi 01-15-2008 10:54 AM
f10 error code
my oven flashes f 10 code after preheat and turns off
Gene 01-15-2008 06:24 PM
Hi Lindi,
In order to provide the most accurate advise I need the complete model number of the oven.
lindi 01-16-2008 08:51 AM
f10 error
model FEF366DCE
Gene 01-16-2008 11:00 AM
Hi Lindi,
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Good luck.
