| » creda range with double oven |
Hi
You need a High Temperature silicone glue to repair your oven and re affix the brackets to the glass. It is Important to clean off the old glue first as otherwise the new glue will not stick to the glass properly. you must also ensure all surfaces to be glued are free from grease. You can buy oven door glue on the internet relatively cheaply - certainly much cheaper option than calling out an engineer or replacing the oven!. Good luck. |
| Display Modes | |
| maytag gemini double oven gas range | debo | Oven Repair (including Ranges and Cooktops) | 1 | 02-04-2010 06:12 PM |
| Gemini Double Oven range 30" | jkpinder | Oven Repair (including Ranges and Cooktops) | 1 | 12-22-2009 05:51 AM |
| Maytag Gemini Double oven gas Range | hwhitworth | Oven Repair (including Ranges and Cooktops) | 0 | 11-03-2009 08:29 PM |
| Creda Refidgerator drain hole for creda 86610 | munawr | Refrigerator & Freezer Repair | 1 | 07-13-2009 09:31 AM |
| Creda Oven | Nick Roberts | Oven Repair (including Ranges and Cooktops) | 1 | 06-30-2008 03:03 PM |
