I just found your site and the forum had a post simalar to my problem. I have used other web sites to try and help me withthe problem.
So far I have replaced the control timmer 2 times and the touch pannel once.
here are some of the problems so far. that I have reported others
I have replaced the timer control unit and the front control pannel but I am still having problems with the oven. when My wife bakes the oven shuts down during the bake cycle. today when she reset it it turned on the oven clean function and lock the oven with the cookies in it. I am stumped please help
I was cooking breakfest using only the front burner when I heard a a motor noise and the oven lock light cme on then went off oven not on the time where do I find the sensor and is it a replaceable part is th oven control different than the timer control?
I have remove the temp sensor and checked th ohms and it reads 1087 on my digital fluke testor
While baking the oven just started turning on and off like a relay problem turned it off at breaker and turned back on it still did the same thing while warm. I have checked the cord connections and they are tight
last night I baked cookies with out a problem.
This is a grimlin i need to find Help
