Discuss
Kenmore Triple Task Gas Range
 in
The triple task oven doesn't work-was used twice and from time to time the gas oven just shuts off and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Triple Task Gas Range
  #1 (permalink)
Old 08-14-2009, 05:07 PM
Junior Member
redhead01 is on a distinguished road
Default Kenmore Triple Task Gas Range
Brand: Kenmore   Age: 1 - 5 years
The triple task oven doesn't work-was used twice and from time to time the gas oven just shuts off and it reads PF.
Have to restart the oven. The triple task oven light comes on but then nothing happens in the oven.
  #2 (permalink)
Old 08-14-2009, 05:08 PM
Junior Member
Default
You may send any help to dkkasper@comcast.net as well. Thank you.
  #3 (permalink)
Old 10-03-2009, 09:05 PM
Junior Member
redm3128 is on a distinguished road
Default mine also
I purchsed Kenmore triple Task Range 3 years ago. I used the bottom oven 1-2 times and then the fuse burnt out and Sears sent a repairman over to replace it. This was done a few times. The last time the repairman told me to just buy the fuses and put it in myself.
This range is a waste of money! I will never buy Kenmore again.
To put in the fuse, you need to pull out the oven, take off the back and go inside the back to insert it. This you need to do every 2nd time you use it. I gave up!!! What a WASTE of $1200.00!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace triple element on Maytag Range RonAJ Oven Repair (including Ranges and Cooktops) 6 11-16-2011 02:45 AM
Kenmore Triple Task oven elements do not work thanksforhelp Oven Repair (including Ranges and Cooktops) 2 09-02-2009 12:36 PM
Kenmore triple agitator Tootan541 Washer Repair 0 06-07-2008 10:13 PM
Kenmore Triple Task Oven not working Syager Oven Repair (including Ranges and Cooktops) 3 01-23-2008 06:35 PM
kenmore oven k1 relay on triple task oven fullauto9 Oven Repair (including Ranges and Cooktops) 5 12-07-2007 11:32 AM
