OVEN LITE FLASHES / CONTROL PANEL CLICKS, CANNOT TURN OFF @ TIMES. IS THE PROBLEM IN THE CONTROL UNIT OR THE MEMBRANE. ALL OTHER FUNCTION APPEAR TO WORK OK.
THANKS, TOM:confused:
Tom,
Open the control panel and remove the key panel ribbon cable from the control board. Restore the power and watch the oven for a day. Post the results. Post the color of the control panel.
