Discuss
Oven with a mind of it's own!
 in
My upper oven was showing an E4 code when I had a service tech. come out (obviously before I found
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven with a mind of it's own!
  #1 (permalink)
Old 01-14-2008, 06:19 PM
Junior Member
clmurguia is on a distinguished road
Default Oven with a mind of it's own!
Model Number: cmt227nw   Brand: Thermador   Age: More than 10 years
My upper oven was showing an E4 code when I had a service tech. come out (obviously before I found this site), I was told I needed to have my control board rebuilt(model is discontinued). I could not afford to have it repaired so I just use the lower oven. I decided to try it again after a year and it showed an E8 code (the microwave still works fine). I just now tried it again for the heck of it and the darn thing is WORKING GREAT!!!! Does this sound like a sensor problem or a control board problem? (please let it be a sensor problem!!!!) I'm hoping this will be something I can fix myself. Any suggestions?
Ads By Google
Related Models
Thermador CMT227W
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA Mwave - Mounted Under Cabinet
Maytag CMV1000ADB Mwave - Mounted Under Cabinet
Maytag CMV1000ADW Mwave - Mounted Under Cabinet
Maytag CMV1000BAB Mwave - Mounted Under Cabinet
Maytag CMV1000BAQ Mwave - Mounted Under Cabinet
Maytag CMV1000BAW Mwave - Mounted Under Cabinet
Maytag CMV1000BDB Mwave - Mounted Under Cabinet
Maytag CMV1000BDQ Mwave - Mounted Under Cabinet
Maytag CMV1000BDW Mwave - Mounted Under Cabinet
Maytag CMV1100AAB Mwave - Mounted Under Cabinet
Maytag CMV1100AAQ Mwave - Mounted Under Cabinet
Maytag CMV1100AAW Mwave - Mounted Under Cabinet
Crosley CMW159PC Mwave - Cntrtp / Stand Alone
Crosley CMW22A2 Mwave - Cntrtp / Stand Alone
Crosley CMW22A6 Mwave - Cntrtp / Stand Alone
Crosley CMW419PD Mwave - Cntrtp / Stand Alone
Crosley CMW464G Mwave - Cntrtp / Stand Alone
Maytag CNDNS229J  Ref - SXS/I&W
Maytag CNDNS229JA  Ref - SXS/I&W
Maytag CNDNS229JH  Ref - SXS/I&W
Maytag CNDNS229K  Ref - SXS/I&W
Maytag CNDNS229KA  Ref - SXS/I&W
Maytag CNE200 Range - F/s Std Ele
Maytag CNE2000ACL Range - F/s Std Ele
Maytag CNE2000ACW Range - F/s Std Ele
Admiral CNEA100ACL Range - F/s Std Ele
Admiral CNEA100ACW Range - F/s Std Ele
Maytag CNG200 Range - F/s Std Gas
Maytag CNG201 Range - F/s Std Gas
Maytag CNG2010AAL Range - F/s Std Gas
Maytag CNG2010AAW Range - F/s Std Gas
Maytag CNG2010BAL Range - F/s Std Gas
Maytag CNG2010BAW Range - F/s Std Gas
Maytag CNNS208  Ref - Sxs
Maytag CNNS208H  Ref - Sxs
Norge CNNS208K Ref - Sxs
Norge CNNS208KA Ref - Sxs
Norge CNNS208KW Ref - Sxs
Maytag CNNT153L  Ref - Top Mount
Maytag CNNT153LA  Ref - Top Mount
Maytag CNNT156K  Ref - Top Mount
Maytag CNNT156KA  Ref - Top Mount
Maytag CNNT156KH  Ref - Top Mount
Maytag CNNT156KL  Ref - Top Mount
Norge CNNT174HL Ref - Top Mount
Norge CNNT174HLA Ref - Top Mount
Norge CNNT174HLH Ref - Top Mount
Maytag CNNT174K  Ref - Top Mount
Maytag CNNT174KA  Ref - Top Mount
Maytag CNNT174KL  Ref - Top Mount
Maytag CNNT174KLA  Ref - Top Mount
Norge CNNT178BV Ref - Top Mount
Norge CNNT178BVA Ref - Top Mount
Norge CNNT178BVH Ref - Top Mount
Maytag CNNT198GA  Ref - Top Mount
Maytag CNNT198GH  Ref - Top Mount
Maytag CNNT198GL Ref - Top Mount
Maytag CNNT198GLA  Ref - Top Mount
Maytag CNNT198GLH  Ref - Top Mount
Maytag CNNT198GLN Ref - Top Mount
Maytag CNNT198GN  Ref - Top Mount
Maytag CNNT198K  Ref - Top Mount
Maytag CNNT198KA  Ref - Top Mount
Maytag CNNT198KL  Ref - Top Mount
Maytag CNNT198KLA  Ref - Top Mount
Crosley CNNT218BV Ref - Top Mount
Crosley CNNT218BVA Ref - Top Mount
Crosley CNNT218BVH Ref - Top Mount
Maytag CNP200 Range - F/s Std Gas
Maytag CNP201 Range - F/s Std Gas
Maytag CNP2010AXL Range - F/s Std Gas
Maytag CNP2010AXW Range - F/s Std Gas
Maytag CNP2010BXL Range - F/s Std Gas
Maytag CNP2010BXW Range - F/s Std Gas
Admiral CNPA100AXL Range - F/s Std Gas
Admiral CNPA100AXW Range - F/s Std Gas
Crosley CNS20M4 Ref - Sxs
Crosley CNS20M4A Ref - Sxs
Crosley CNS20M4H Ref - Sxs
Crosley CNS20M6 Ref - Sxs
Crosley CNS20M6A Ref - Sxs
Crosley CNS20M6H Ref - Sxs
Crosley CNS20T6 Ref - Sxs
Crosley CNS20T6A Ref - Sxs
Crosley CNS20T6H Ref - Sxs
Crosley CNS22M6 Ref - Sxs
Crosley CNS22M6A Ref - Sxs
Crosley CNS22M6H Ref - Sxs
Crosley CNS22T6 Ref - Sxs
Crosley CNS22T6A Ref - Sxs
Crosley CNS22T6H Ref - Sxs
Crosley CNS22V6 Ref - Sxs
Crosley CNS22V6A Ref - Sxs
Crosley CNS22V8 Ref - Sxs
Crosley CNS22V8A Ref - Sxs
  #2 (permalink)
Old 01-15-2008, 06:18 AM
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
e4 is a shorted oven sensor and an e8 is a bad board...
__________________
regards
jim
  #3 (permalink)
Old 01-15-2008, 10:45 AM
Junior Member
Default
Being that it is working at the moment, does that sound more like a bad board rather than a sensor, or could it be both?
  #4 (permalink)
Old 01-16-2008, 04:45 AM
Senior Expert
APP Volunteer
Default
usually not both... need to ohm out sensor at the board .. i think it is a 9 pin connector and there are two wires that come from the connector to the sensor .. should get 1080 ohms at room temperature... then, check from each leg of the sensor to chassis ground.. you should NOT get any continuity.. if you do, then it is definitely a bad sensor .. Also check the wires to make sure neither of them are PINCHED !!!! most often, a bad board is always a bad board.. usually not intermittent..
__________________
regards
jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Keep in mind the areas where a particular micky143 Microwave Repair 0 02-19-2010 10:33 PM
Mind of its own! terrylrs Dishwasher Repair 2 10-23-2009 06:32 AM
mind of its own 2040820408 Washer Repair 0 11-12-2007 12:47 PM
