Discuss
bake ignator won't turn on
 in
the 30" slide-in magic chef came with the house. the broiler ignator works on hi only but not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bake ignator won't turn on
  #1 (permalink)
Old 08-14-2009, 08:40 AM
irenec irenec is offline
Junior Member
irenec is on a distinguished road
Default bake ignator won't turn on
Model Number: s-64h-4tkxw   Brand: Magic Chef   Age: More than 10 years
the broiler ignator works on hi only but not the low setting. all the burners work on top.
the bake ignator doesn't work. could not bake.
i can't afford to replace with a new gas range. i was quoted with a very high repair cost and was also told that it was difficult to replace the parts.
your advice and help with this repair problem would greatly be appreciated. how costly would it be for the parts if the repair can be done?
thanks!
Related Models
Amana S100 Range - S/i Std Ddraft Ele
Jenn-Air S100 Range - S/i Std Ddraft Ele
Hoover S1003
Hoover S1005--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Jenn-Air S101 Range - S/i Std Ddraft Ele
Hoover S1015--- Port - Slim Style,suitcase,power,compact
Hoover S1015030 Port - Slim Style,suitcase,power,compact
Hoover S1015031 Port - Slim Style,suitcase,power,compact
Hoover S1015032 Port - Slim Style,suitcase,power,compact
Hoover S1015033 Port - Slim Style,suitcase,power,compact
Hoover S1015075 Port - Slim Style,suitcase,power,compact
Hoover S1017
Hoover S1019--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1019030 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1021--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1021030 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1029--- Port - Slim Style,suitcase,power,compact
Hoover S1029075 Port - Slim Style,suitcase,power,compact
Hoover S1049--- Port - Slim Style,suitcase,power,compact
Hoover S1049-22
Hoover S1049060 Port - Slim Style,suitcase,power,compact
Jenn-Air S105 Range - S/i Std Ddraft Ele
Jenn-Air S105-C Range - S/i Std Ddraft Ele
Admiral S1050EH-Z Range - F/s Std Ele
Admiral S1050EJ-Z Range - F/s Std Ele
Hoover S1055
Hoover S1057300
Hoover S1057400
Hoover S1057600 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1057700
Hoover S1057800
Hoover S1059--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1059030 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1059130 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1059600 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1061
Hoover S1063
Admiral S1068H-CZW Range - S/c S/i Ele
Admiral S1068J-CHZW Range - S/c D/i Ele
General Electric S1070A0WW Washer
General Electric S1070A1WW Washer
General Electric S1070A2WW Washer
General Electric S1070A4WW Washer
General Electric S1070A5WW Washer
Admiral S1070EH-KZ Range - F/s Std Gas
Admiral S1070EH-Z Range - F/s Std Gas
Admiral S1070EJ-KZ Range - F/s Std Gas
Admiral S1070EJ-Z Range - F/s Std Gas
Hoover S1071--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1071800 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1073--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1075--- Port - Slim Style,suitcase,power,compact
Hoover S1075033
Hoover S1075060 Port - Slim Style,suitcase,power,compact
Hoover S1077--- Port - Slim Style,suitcase,power,compact
Hoover S1077060 Port - Slim Style,suitcase,power,compact
Admiral S1078EH-KZ Range - F/s Std Gas
Admiral S1078H-KLVW Range - F/s Cont Clean Gas
Admiral S1078W-KLVW Range - F/s Cont Clean Gas
Hoover S1079--- Port - Slim Style,suitcase,power,compact
Hoover S1079060 Port - Slim Style,suitcase,power,compact
Hoover S1083--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1083100 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1088H-CKZW Range - S/c S/i Gas
Admiral S1088J-TKZW Range - S/c S/i Gas
Hoover S1093
Hoover S1095
Jenn-Air S110 Range - S/i Std Ddraft Ele
Hoover S1101---
Hoover S1103--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1105--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1112--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1112050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1114--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1117900 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1117981 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1120--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1120050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1127--- Port - Slim Style,suitcase,power,compact
Hoover S1133--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1135--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1137--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1137980 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1141--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover S1147900 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1151L-30 Surface Unit - Ele
Admiral S1151L-36G Surface Unit - Ele
Hoover S1156--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Admiral S1171L-30 Surface Unit - Gas
Admiral S1171L-30K Surface Unit - Gas
Admiral S1171L-36GK Surface Unit - Gas
Admiral S1172L-30K Surface Unit - Gas
Jenn-Air S120 Range - S/c S/i Ddraft Ele
Jenn-Air S120-C Range - S/c S/i Ddraft Ele
Jenn-Air S121 Range - S/c S/i Ddraft Ele
Hoover S1211--- Port - Slim Style,suitcase,power,compact
Hoover S1215--- Port - Slim Style,suitcase,power,compact
Hoover S1221--- Port - Slim Style,suitcase,power,compact
Hoover S1223--- Port - Slim Style,suitcase,power,compact
Jenn-Air S125 Range - S/c S/i Ddraft Ele
Jenn-Air S125-C Range - S/c S/i Ddraft Ele
Hoover S1311--- Port - Slim Style,suitcase,power,compact
Hoover S1311020 Port - Slim Style,suitcase,power,compact
Hoover S1315--- Port - Slim Style,suitcase,power,compact
Hoover S1319--- Port - Slim Style,suitcase,power,compact
Hoover S1323--- Port - Slim Style,suitcase,power,compact
Hoover S1329--- Port - Slim Style,suitcase,power,compact
Hoover S1331--- Port - Slim Style,suitcase,power,compact
Hoover S1335--- Port - Slim Style,suitcase,power,compact
Hoover S1337--- Port - Slim Style,suitcase,power,compact
Hoover S1339--- Port - Slim Style,suitcase,power,compact
Hoover S1347--- Port - Slim Style,suitcase,power,compact
Hoover S1349--- Port - Slim Style,suitcase,power,compact
Hoover S1353--- Port - Slim Style,suitcase,power,compact
Jenn-Air S136 Range - S/c S/i Ddraft Ele
Jenn-Air S136-C Range - S/c S/i Ddraft Ele
Hoover S1361---
  #2 (permalink)
Old 08-14-2009, 09:13 AM
Frank / APP Team's Avatar
Frank / APP Team Frank / APP Team is offline
Senior Expert
Frank / APP Team is on a distinguished road
Default
thanks!
You're going to need to remove the oven bottom to access the bake ignitor. Once the bottom is out of the oven you'll see the flame spreader, it should be held on with of wing nuts. Under that you'll see the burner with the ignitor attached to the side of it. If you don't see that it's actually broken you're going to need a volt meter to see if it's getting 120 volts to it when you turn the oven on.
Beyond that there are a number of components that come into play. The safety valve, wiring, and the control itself. I know it's not what you want to hear but a repairman may need to come to the rescue.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bake Element won't turn on Irishman Oven Repair (including Ranges and Cooktops) 7 06-05-2009 11:52 PM
Stove would not turn off had to turn off breaker Jim Cllen Oven Repair (including Ranges and Cooktops) 1 02-18-2009 06:42 PM
Electronic Oven Ignator vsuboni Oven Repair (including Ranges and Cooktops) 17 11-12-2008 05:25 PM
Bake will not turn on Steve B. Oven Repair (including Ranges and Cooktops) 5 06-18-2008 07:02 PM
Bake Element and BAKE cycle not working jeffman Oven Repair (including Ranges and Cooktops) 1 08-04-2007 11:18 PM
