The broiler element will not work even through I just put a new one in any ideas Teresa
Groups: APP Team
Hello, Teresa. There is a thermal fuse in the broil circuit, top rear of the range. With power off take one lid off the fuse and check the continuity. If it's open - replace it. It is marked #17 on attached diagram. The thermal fuse Part number: AP2989423
