| » Kitchenaid Electric/Microwave Oven Control Panel Replacement |
Model Number: KEMS307DWH4 Brand: Kitchen Aid Age: More than 10 years
How do I replace the the control panel on my 12 year old Kitchenaid Electric/Microwave Combination oven? I've pretty much determined that this part is faulty because the door locks up, the cooling fans runs, it displays "too hot" if I push bake. BTW, I was broiling, not cleaning, when this happened. Turning off the breaker does not reset it. I can get the door open when the breaker is off, but it just locks right back up when I turn the breaker on.
Does this sound like a new control panel is needed? and if so, how do I go about accessing the old one to replace it? Ads By Google Related Models |
If you unplug the sensor from the control board you can measure its resistance at room temp ... should be about 1090 ohms at 70 F. Here's a link to the tech sheet if you don't have it.
http://www.servicematters.com/docs/w...%204454773.pdf Bruce |
| Display Modes | |
| kitchenaid convection oven control panel preplacement | Rby607 | Oven Repair (including Ranges and Cooktops) | 0 | 11-22-2009 06:34 AM |
| Kitchenaid Oven Control Panel Installation | Stillwater | Oven Repair (including Ranges and Cooktops) | 4 | 08-02-2009 06:24 AM |
| Oven Electric Control panel is off | moe torabi | Oven Repair (including Ranges and Cooktops) | 2 | 04-04-2009 12:52 PM |
| Electric oven control panel removal | stpedson | Oven Repair (including Ranges and Cooktops) | 1 | 03-14-2009 08:53 PM |
| Everything on oven works except electric control panel | Theredman | Oven Repair (including Ranges and Cooktops) | 3 | 01-05-2009 04:16 AM |
