Discuss
Oven will not heat up
 in
GE Oven does not heat up. Bottom burner does not light.......removed bottom and ignitor does not get hot. Broiler (
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat up
  #1 (permalink)
Old 08-13-2009, 05:38 AM
ggrek123 ggrek123 is offline
Junior Member
ggrek123 is on a distinguished road
Default Oven will not heat up
Model Number: GEBP90MEB2BC   Brand: GE   Age: 5 - 10 years
GE Oven does not heat up. Bottom burner does not light.......removed bottom and ignitor does not get hot. Broiler (Top Oven Burner lights) & Stove top work fine. Do I need to replace Ignitor?
Related Models
Whirlpool GEC9858EQ0
Whirlpool GEC9858EQ1
Whirlpool GEC9858EZ0
Whirlpool GEC9858EZ1
Whirlpool GEC9858HQ0
Whirlpool GEC9858HQ1
Whirlpool GEC9858HZ0
Whirlpool GEC9858HZ1
Frigidaire GED15P1 Gib(v1) / Dehumidifier
Frigidaire GED25P1 Gib(v1) / Dehumidifier
Frigidaire GED30P1 Gib(v2) / Dehumidifier
Frigidaire GED40P2 Gib(v3) / Dehumidifier
Frigidaire GED50P1 Gib(v4) / Dehumidifier
Frigidaire GEF300PADA Gib(v1) / Electric Range
Frigidaire GEF300PAWA Gib(v2) / Electric Range
Frigidaire GEF301SADA Gib(v2) / Electric Range
Frigidaire GEF301SAWA Gib(v1) / Electric Range
Gibson GEF305PJSA Gibson/electric Range
Gibson GEF305PJSB Gibson/electric Range
Frigidaire GEF311WADA Gib(v2) / Electric Range
Frigidaire GEF311WAWA Gib(v1) / Electric Range
Frigidaire GEF312BADA Gib(v1) / Electric Range
Frigidaire GEF312BAWA Gib(v2) / Electric Range
Frigidaire GEF322BBDA Gib(v1) / Electric Range
Frigidaire GEF322BBDB Gib(v1) / Electric Range
Frigidaire GEF322BBDC Gib(v1) / Electric Range
Frigidaire GEF322BBWA Gib(v2) / Electric Range
Frigidaire GEF322BBWB Gib(v2) / Electric Range
Frigidaire GEF322BBWC Gib(v2) / Electric Range
Frigidaire GEF322WBDA Gib(v3) / Electric Range
Frigidaire GEF322WBDB Gib(v3) / Electric Range
Frigidaire GEF322WBDC Gib(v4) / Electric Range
Frigidaire GEF322WBDD Gib(v3) / Electric Range
Frigidaire GEF322WBWA Gib(v4) / Electric Range
Frigidaire GEF322WBWB Gib(v5) / Electric Range
Frigidaire GEF322WBWC Gib(v6) / Electric Range
Frigidaire GEF322WBWD Gib(v4) / Electric Range
Frigidaire GEF324BFDA Gib(v1) / Electric Range
Frigidaire GEF324BFWA Gib(v2) / Electric Range
Gibson GEF331AS0 Dryer - Gibson
Gibson GEF331AS1 Dryer - Gibson
Gibson GEF331AS2 Gibson/electric Dryer
Gibson GEF331CS0 Gibson/dryer
Frigidaire GEF350SBDA Gib(v1) / Electric Range
Frigidaire GEF350SBDB Gib(v1) / Electric Range
Frigidaire GEF350SBDC Gib(v1) / Electric Range
Frigidaire GEF350SBWA Gib(v2) / Electric Range
Frigidaire GEF350SBWB Gib(v2) / Electric Range
Frigidaire GEF350SBWC Gib(v2) / Electric Range
Gibson GEF351FSA Gibson/electric Range
Gibson GEF352BHDB Gibson/electric Range
Gibson GEF352BHWB Gibson/electric Range
Gibson GEF352CHSB Gibson/electric Range
Frigidaire GEF354BADA Frg(v1) / Electric Range
Frigidaire GEF354BAWA Frg(v2) / Electric Range
Frigidaire GEF354BBDA Gib(v1) / Electric Range
Frigidaire GEF354BBDB Gib(v1) / Electric Range
Frigidaire GEF354BBDC Gib(v1) / Electric Range
Frigidaire GEF354BBWA Gib(v2) / Electric Range
Frigidaire GEF354BBWB Gib(v2) / Electric Range
Frigidaire GEF354BBWC Gib(v2) / Electric Range
Frigidaire GEF355BFDA Gib(v1) / Electric Range
Frigidaire GEF355BFWA Gib(v2) / Electric Range
Frigidaire GEF355CFSA Gib(v0) / Electric Range
Frigidaire GEF357BABA Gib(v1) / Electric Range
Frigidaire GEF357BABB Gib(v2) / Electric Range
Frigidaire GEF357CBSA Gib(v1) / Electric Range
Frigidaire GEF357CBSB Gib(v0) / Electric Range
Frigidaire GEF357CBSC Gib(v1) / Electric Range
Frigidaire GEF357CBSD Gib(v2) / Electric Range
Frigidaire GEF357CBTA Gib(v2) / Electric Range
Frigidaire GEF357CBTB Gib(v0) / Electric Range
Frigidaire GEF357CBTC Gib(v3) / Electric Range
Frigidaire GEF357CBTD Gib(v4) / Electric Range
Frigidaire GEF400WAW1 Gib(v2) / Electric Range
Frigidaire GEF400WAWA Gib(v1) / Electric Range
Whirlpool GEN2000HQ0
Whirlpool GEN2000HQ1
Whirlpool GEN2000HZ0
Whirlpool GEN2000HZ1
Whirlpool GEQ8811KQ0
Whirlpool GEQ8811KT0
Whirlpool GEQ8811LG0
Whirlpool GEQ8811LG1 27"electric Dryer
Whirlpool GEQ8811LL0
Whirlpool GEQ8811LL1 27"electric Dryer
Whirlpool GEQ8811LW0
Whirlpool GEQ8811LW1 27"electric Dryer
Whirlpool GEQ8811PG0 27"electric Dryer
Whirlpool GEQ8811PG1 27"electric Dryer
Whirlpool GEQ8811PL0 27"electric Dryer
Whirlpool GEQ8811PL1 27"electric Dryer
Whirlpool GEQ8811PW0 27"electric Dryer
Whirlpool GEQ8811PW1 27"electric Dryer
Whirlpool GEQ8821KQ0
Whirlpool GEQ8821KT0
Whirlpool GEQ8821LL0
Whirlpool GEQ8821LL1 27"electric Dryer
Whirlpool GEQ8821LW0
Whirlpool GEQ8821LW1 27"electric Dryer
Whirlpool GEQ8831LL0 27"electric Dryer
Whirlpool GEQ8831LW0 27"electric Dryer
Whirlpool GEQ8858EQ0
Whirlpool GEQ8858EZ0
Whirlpool GEQ8858HQ0
Whirlpool GEQ8858HQ1
Whirlpool GEQ8858HZ0
Whirlpool GEQ8858HZ1
Whirlpool GEQ8858JQ0
Whirlpool GEQ8858JQ1
Whirlpool GEQ8858JT0
Whirlpool GEQ8858JT1
Whirlpool GEQ8858KQ0
Whirlpool GEQ8858KT0
Whirlpool GEQ9800LG0
Whirlpool GEQ9800LG1 27"electric Dryer
Whirlpool GEQ9800LW0
Whirlpool GEQ9800LW1 27"electric Dryer
Whirlpool GEQ9800PB0 27"electric Dryer
Whirlpool GEQ9800PB1 27" Electric Dryer
  #2 (permalink)
Old 08-13-2009, 01:28 PM
ce_carrell ce_carrell is offline
Junior Member
ce_carrell is on a distinguished road
Post same problem
I have the same problem with my GE gas range. It just happened last night when trying to use it. My top burners and broiler are working fine. I have no idea what is the problem.
Quote:
  #3 (permalink)
Old 08-13-2009, 04:44 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Most likely the problem is a bad oven igniter. If you would like to confirm it then you have to check the igniter for continuity or check for 120 VAC to the igniter while the control calls for Bake.
If there is no continuity or if there is proper voltage then the igniter is the culprit.
- The Bake igniter Part number: AP2014008
Here are the breakdown diagrams and Replacement parts for GE JGBP90MEB2BC | AppliancePartsPros.com
__________________
  #4 (permalink)
Old 08-13-2009, 04:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What is the complete model number of the range?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven lock light is on and oven will not heat jimfunke Oven Repair (including Ranges and Cooktops) 0 04-20-2009 10:06 AM
oven lock light is on and oven will not heat jimfunke Oven Repair (including Ranges and Cooktops) 0 04-20-2009 10:02 AM
Caloric double oven/bottom oven doesn't heat kj0505 Oven Repair (including Ranges and Cooktops) 1 12-10-2008 10:14 AM
oven lighter comes on but oven doesn't heat dack Oven Repair (including Ranges and Cooktops) 1 10-27-2008 04:31 PM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 10:56 AM
