Hi. I tried using the auto clean option on my oven, at first I came back after five minutes and it said PF. So, then I turned it back on to auto clean, and this time after a few minutes it said E2-F3. I read somewhere online that the temperature sensor may need to be replaced or that the control panel itself. Is this true? Is this something I can do myself? Is there a way to test to see what has gone? Thank you.
Update: I tested the temperature probe and got an ohm reading of 1080ohms.
Groups: APP Team
Hello. The error code F2-E3 means ether bad temperature sensor or bad control board. You already tested the sensor- 1080 ohms is a good reading. I'd like you to check sensor plugs and take one more measurement at the control board plug. If it's the same than replace the board. The control board Part number: AP4982698
