I have an older duel stack oven and I am getting an error code F2 on screen. It used to only happen when I had the oven in use so I stopped and started to use lower oven and now the code is appearing when ever it wants. I have read that it is a sensor or relay issue but I am not sure where the probe is located. Is the the one at the top back sticking forward or another one in there? Help!!!
