Bought a used Maytag Gemini MER6770AAW Electric w/double ovens. Removed oven doors to make it lighter to carry.
Replaced doors, plugged it in and received a F1-A fault. A quick code lookup indicates something about the upper door latch. I am not sure what I should be checking for.
Also, one of the hot surface indicator lights is on whenever the range is plugged in.
Any help would be appreciated.
