We purchased this stove from a friend a month ago, they had it a couple years I guess, its in very good shape. It seems to work ok. I cleaned the Burner Heads per the manual and the tiny hole is not clogged. Turning on the burners you hear the ignighter sparking ok, and hear the gas. But it will not ignight until you hold something over the back where the ignighter is, kind of the little open space behind it/. As soon as you hold like a fork or a piece of wood it flames on. And it seems to be for each of the Burner heads. It sounds like a lot of gas is coming out but the flame is not very prominent. Just not sure what is going on. Why it wont light like it should. Can anyone shed any light on this/
Thank you
