This Thermador is LP gas and it preheats fine but the oven never gets up to the requested heat range, even after 15 minutes. I need a wiring diagram to verify that the harness is correctly wired to the Control Board. Also I noticed that there are error codes to assist in troubleshooting, but where are they located?
Thank you Shelly
