Bottom burner (bake burner) will not light, broiler works fine Thought it was a bad igniter. Switched the igniters from the top and bottom burners and still had the problem. This would leave me to believe that the gas valve is bad. My question is would a bad gas valve create this problem. I would hate to replace these parts to still have the same problem
Thanks for your input
Jim
