| » Range door not flush |
Model Number: D120 Brand: Jenn-Air Age: More than 10 years
One door hinge, Part #71002472, was replaced 8 years ago. The door is not flush. The right side is at least 1/2 inch away from flush. How to remedy? Much heat escapes.
Quote:
There are a few things to check before you replace the hinges : Remove the oven door, and set it on a flat surface and check the door assembly for warpage, and if bent. In a lot of cases you can loosen or remove the frame screws and you can usually "tweak" the door panel back into shape. With the door removed, check the front flange of the oven opening, for distortion around the hinge mounting screws, and for cracked or chipped porcelain, and the the condition of the hinge pivots, and mounting screws. Make sure the door is level and the gasket is not "dragging" on the oven cavity on the side that remains open. You can make adjustments with the screw on the top portion of the hinge assembly. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Flush doors on a recessed refrigerator. | bene | Refrigerator & Freezer Repair | 0 | 12-01-2009 07:09 PM |
| Fridge Door does not close flush | latourrett | Refrigerator & Freezer Repair | 5 | 04-04-2009 04:32 AM |
| Oven isnt flush to the wall | stove help | Oven Repair (including Ranges and Cooktops) | 1 | 09-08-2008 02:39 PM |
| My Washer Doesn't Flush Out The Water | Oscar10 | Washer Repair | 1 | 02-20-2008 01:24 PM |
