Discuss
Gas Range Won't Shut Off
 in
Hi, I came home from work today and found my Maytag Gas Oven was ON even thought the thermostat knob
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Range Won't Shut Off
  #1 (permalink)
Old 08-07-2009, 06:13 PM
Junior Member
Dan Blair is on a distinguished road
Default Gas Range Won't Shut Off
Model Number: CRG7500AAE   Brand: Maytag   Age: More than 10 years
I came home from work today and found my Maytag Gas Oven was ON even thought the thermostat knob was set to OFF. I turned the knob to its maximum ON position then back to off and the oven turned off for about two minutes and then relit while still in the off position. I did this several times and every time the oven went off, but only stayed off for several minutes before turning back on even thought the thermostat knob was off. The only way to get it to stay off was to unplug it. I am guessing I need to replace the thermostat, does this sound correct or could something else be wrong.
Thanks for your assistance.
Dan Blair
Ads By Google
Related Models
Maytag CRG7500AAE RANGE- F/S STD GAS
Maytag CRG7500AAL RANGE- F/S STD GAS
Maytag CRG7500AAW RANGE- F/S STD GAS
Maytag CRG7500CAE RANGE- F/S STD GAS
Maytag CRG7500CAL RANGE- F/S STD GAS
Maytag CRG7500CAW RANGE- F/S STD GAS
Admiral CRG7500CGE RANGE- F/S STD GAS
Admiral CRG7500CGW RANGE- F/S STD GAS
Maytag CRG755 RANGE- S/C F/S GAS
Maytag CRG760 RANGE- S/C F/S GAS
Maytag CRG7600AAL RANGE-F/S CONT CLEAN GAS
Maytag CRG7600AAW RANGE-F/S CONT CLEAN GAS
Maytag CRG760A RANGE- S/C F/S GAS
Maytag CRG7700AAL RANGE- F/S STD GAS
Maytag CRG7700AAW RANGE- F/S STD GAS
Maytag CRG7700BAL RANGE- F/S STD GAS
Maytag CRG7700BAW RANGE- F/S STD GAS
Maytag CRG7700CAL RANGE- F/S STD GAS
Maytag CRG7700CAW RANGE- F/S STD GAS
Maytag CRG783 RANGE- S/C F/S GAS
Maytag CRG800 RANGE- S/C F/S GAS
Maytag CRG805 RANGE- S/C F/S GAS
Maytag CRG8200AAL RANGE- F/S STD GAS
Maytag CRG8200AAW RANGE- F/S STD GAS
Maytag CRG8200BAL RANGE- F/S STD GAS
Maytag CRG8200BAW RANGE- F/S STD GAS
Maytag CRG8200CAL RANGE- F/S STD GAS
Maytag CRG8200CAW RANGE- F/S STD GAS
Maytag CRG8400AAL RANGE- F/S STD GAS
Maytag CRG8400AAW RANGE- F/S STD GAS
Maytag CRG860 RANGE- S/C F/S GAS
Maytag CRG8600AAB RANGE- S/C F/S GAS
Maytag CRG8600AAL RANGE- S/C F/S GAS
Maytag CRG8600AAW RANGE- S/C F/S GAS
Maytag CRG8600BAB RANGE- S/C F/S GAS
Maytag CRG8600BAL RANGE- S/C F/S GAS
Maytag CRG8600BAW RANGE- S/C F/S GAS
Maytag CRG860A RANGE- S/C F/S GAS
Maytag CRG9300CAL RANGE- S/C F/S GAS
Maytag CRG9300CAW RANGE- S/C F/S GAS
Maytag CRG9600AAL RANGE- S/C F/S GAS
Maytag CRG9600AAW RANGE- S/C F/S GAS
Maytag CRG9700AAL RANGE- S/C F/S GAS
Maytag CRG9700AAW RANGE- S/C F/S GAS
Maytag CRG9700BAL RANGE- S/C F/S GAS
Maytag CRG9700BAW RANGE- S/C F/S GAS
Maytag CRG9700CAE RANGE- S/C F/S GAS
Maytag CRG9700CAL RANGE- S/C F/S GAS
Maytag CRG9700CAM RANGE- S/C F/S GAS
Maytag CRG9700CAW RANGE- S/C F/S GAS
Admiral CRG9700CGE RANGE- S/C F/S GAS
Admiral CRG9700CGM RANGE- S/C F/S GAS
Maytag CRG9800AAB RANGE- S/C F/S GAS
Maytag CRG9800AAE RANGE- S/C F/S GAS
Maytag CRG9800AAL RANGE- S/C F/S GAS
Maytag CRG9800AAW RANGE- S/C F/S GAS
Maytag CRG9800BAB RANGE- S/C F/S GAS
Maytag CRG9800BAE RANGE- S/C F/S GAS
Maytag CRG9800BAL RANGE- S/C F/S GAS
Maytag CRG9800BAM RANGE- S/C F/S GAS
Maytag CRG9800BAW RANGE- S/C F/S GAS
Maytag CRG9800CAB RANGE- S/C F/S GAS
Maytag CRG9800CAE RANGE- S/C F/S GAS
Maytag CRG9800CAM RANGE- S/C F/S GAS
Maytag CRG9830CAB RANGE- S/C F/S GAS
Maytag CRG9830CAE RANGE- S/C F/S GAS
Maytag CRG9830CAM RANGE- S/C F/S GAS
Admiral CRGA250AAL RANGE- F/S STD GAS
Admiral CRGA250AAW RANGE- F/S STD GAS
Admiral CRGA250BAL RANGE- F/S STD GAS
Admiral CRGA250BAW RANGE- F/S STD GAS
Admiral CRGA300AAL RANGE- F/S STD GAS
Admiral CRGA300AAW RANGE- F/S STD GAS
Admiral CRGA300BAL RANGE- F/S STD GAS
Admiral CRGA300BAW RANGE- F/S STD GAS
Admiral CRGA350AAL RANGE- F/S STD GAS
Admiral CRGA350AAW RANGE- F/S STD GAS
Admiral CRGA400AAL RANGE- F/S STD GAS
Admiral CRGA400AAW RANGE- F/S STD GAS
Admiral CRGA400BAL RANGE- F/S STD GAS
Admiral CRGA400BAW RANGE- F/S STD GAS
Admiral CRGA500AAL RANGE- F/S STD GAS
Admiral CRGA500AAW RANGE- F/S STD GAS
Admiral CRGA600AAL RANGE- S/C F/S GAS
Admiral CRGA600AAW RANGE- S/C F/S GAS
Admiral CRGA650AAL RANGE- S/C F/S GAS
Admiral CRGA650AAW RANGE- S/C F/S GAS
Admiral CRGA700AAL RANGE- S/C F/S GAS
Admiral CRGA700AAW RANGE- S/C F/S GAS
Admiral CRGA800AAE RANGE- F/S STD GAS
Admiral CRGA800AAL RANGE- F/S STD GAS
Admiral CRGA800AAW RANGE- F/S STD GAS
Frigidaire CRGF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CRGF342AS1 Dryer - Frig/best Buy
Frigidaire CRGF342AS2 Frigidaire/gas Range
Frigidaire CRGF342AS3 Frigidaire/gas Dryer
Frigidaire CRGF342AS4 Frigidaire/dryer
Frigidaire CRGR442AS0 Dryer - Frig/best Buy
Frigidaire CRGR442AS1 Dryer - Frig/best Buy
Frigidaire CRGR442AS2 Dryer - Frig/best Buy
Frigidaire CRGR5700AS0 Dryer - Frig/best Buy
Frigidaire CRGR5700AS1 Frigidaire/gas Dryer
Frigidaire CRGR5700AS2 Frigidaire/gas Dryer
Frigidaire CRGR5700AS3 Frigidaire/dryer
Frigidaire CRGR7900AS0 Dryer - Frig/best Buy
Frigidaire CRGR7900AS1 Frigidaire/gas Dryer
Frigidaire CRGR7900AS2 Frigidaire/gas Dryer
Frigidaire CRGR7900AS3 Frigidaire/dryer
Amana CRH4-1 COMMERCIAL MICROWAVES
Amana CRH4-3 COMMERCIAL MICROWAVES
Amana CRH5-1 COMMERCIAL MICROWAVES
Amana CRH5-3 COMMERCIAL MICROWAVES
Admiral CRL5300BXA RANGE- F/S STD GAS
Admiral CRL5300BXW RANGE- F/S STD GAS
Admiral CRL5300CXL RANGE- F/S STD GAS
Admiral CRL5300CXW RANGE- F/S STD GAS
  #2 (permalink)
Old 08-10-2009, 07:53 AM
Junior Member
wp2008 is on a distinguished road
Default
You need to contact Maytag at 1 (800) 344-1274 about this issue.
  #3 (permalink)
Old 08-11-2009, 05:15 PM
Junior Member
Default
I will contact Maytag. Am I on the right track thinking the thermostat has failed?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Gas Range Broiler will not shut off korybw Oven Repair (including Ranges and Cooktops) 1 08-14-2009 06:02 PM
kenmore electric range oven wont shut off nrmrz Oven Repair (including Ranges and Cooktops) 0 07-23-2009 02:45 PM
Kenmore Gas Range intermittant shut-off primegm Oven Repair (including Ranges and Cooktops) 4 03-03-2009 07:16 AM
Kenmore Range cooktop on/off indicator wont shut off richrizz Oven Repair (including Ranges and Cooktops) 1 06-13-2008 05:46 PM
Broiler in range will not shut off Hayes Oven Repair (including Ranges and Cooktops) 1 05-29-2008 12:27 PM
