ROYR8115
#1 Posted : Wednesday, March 7, 2012 3:42:45 PM(UTC)
ROYR8115
I am trying to change out the dual switch for dual burner on this cooktop.
The old part no. was 318078200. The replacement part no. is 903097-050. The problem is there is no conversion diagram to show where wires should be plugged in on new switch. I need help. The correct Model no. is FEC30S8HSA
Simon / APP Team
#2 Posted : Wednesday, March 7, 2012 4:29:52 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This is the rewiring instructions Blk. wire with a jumper feed will feed both P-2's. Orange # 18 gauge wire goes to the pilot and the # 4 switch connection. Red wire #16 gauge jumper is from the # terminal to the inner element connection. This is the same side that hooks to the limiter which the other end of the limiter is a brown # 16 gauge wire going to the #2 connection of the R.F. Sw. The other side of the switch has a red # 16 gauge wire hooks to it from the jumper to L-2 connection of the RT.R. Sw., jumping to the Lt. rear sw.(@L_2) finally dead front at (ending) the P-1 connection on the Lt. front switch. The limiter has a black #18 gauge wire connected to it that is a jumper series to all limiters on the same connection. The limiter has a brown,gray or an orange #18 gauge feeding one side of the hot surface l.e.d. indicator bulb. There is a red # 16 gauge wire that goes to the P1 connection of the switch, opposite of the brown wire on #2 connection going to the limiter. Thank you.
Read more: FRIGIDAIRE Switch - Dual, part number: AP3775555
Appliance Parts Pros.com Discount Appliance Parts
The correct purt number for dual switch is 903057-9010.
ROYR8115
#3 Posted : Thursday, March 8, 2012 7:30:52 AM(UTC)
ROYR8115
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
I am posting pictures of the old and new switches. I have identified the color wire that hooks to each terminal on old switch. I do not see the # terminal highlighted in your post. Any help is appreciated.
UserPostedImage
https://skydrive.live.co...authkey=!AJ0yNzEg3Y4MRxc
stevenmh
#4 Posted : Thursday, April 5, 2012 10:51:07 AM(UTC)
stevenmh
I have a Frigidaire Gallery Cooktop and replaced the dual switch number 903057-9010 twice now. I ordered a third switch and received part number 903097-9050. I was told it replaced the previous part. It is a much sturdier switch but I cannot find a wiring diagram for it (I spent half a day calling and searching online). Your recent post describes wiring for the 903057-9010 switch and I have that diagram, but the 903097-9050 connections are different from that and the original switch.
Please tell me what color wires connect to the following terminals on the 903097-9050 switch: P1, P2, S1, S2, 4 and 4a. Or send a diagram if available. Thank you, stevenmh
stevenmh
#5 Posted : Tuesday, April 24, 2012 1:45:00 PM(UTC)
stevenmh
I have a Frigidaire FEC 30S8HSA cook top. The front dual burner switch has broken three times, the original and two 903057-9010 switches. I ordered another switch and they sent me a 903097-9050 switch. Attached are the original and 903057-9010 wiring diagrams. Please tell me how to wire the 903097-9050 switch to the FEC 30S8HSA cook top. Thank you.
stevenmh attached the following image(s):
Adam / APP Team
#6 Posted : Wednesday, April 25, 2012 9:03:21 AM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
According to the manufacturer part number 903057-9010 doesn't sub to 903097-9050. So you may have the wrong switch.
According to your model the final replacement switches are 903057-9010 and 318120505. Which means the 903097-9050 doesn't belong to your model.
If you purchased it from us please call our toll free number 1-877-477-7278 and one of our qualified representatives will be glad to assist you.
Jenn-Air JED8430 dual switch replacement (Oven Repair (including Ranges and Cooktops))
by HopesnHim 9/1/2010 5:24:44 PM(UTC)
