My tenant has just reported the oven is not heating. Its possible that the last time it was used was when I did a self-cleaning prior to them moving in. Its also possible (though I can't remember for certain) that I incorrectly stopped the self clean cycle. Since the rental is 45 minutes away, I would like to know in advance what to look for to help diagnose the problem. If I did screw up the self clean, how do I reset? If thats not the problem would it be an element? Would both not work at the same time? What else should I look for and are their diagrams of my model somewhere to help? The tenant does state that the range top is working fine.
Thanks in advance!
Cynthia
ok tenant just stated that they had been using it and now it doesn't work, so its not me and its not a screwed up self clean. Neither element heats, any thoughts?
