Oven door won't close completey. I removed the door and checked both hinges and attachments. All appear straight and operating properly but door still won't close. I can push it shut but it won't stay closed. Remains open about one inch.
Groups: APP Team
Hello. First of all check for any obstructions - door gasket, racks, bottom panel. If everything checks OK most likely the problem is bad hinges and receptacles. The hinge kit Part number: AP3844318
