My Kitchen Aid Thermal Convection Oven works fine. The only problem is that the 4 gas burners igniter clicks even when the burner is on. For temp fix, I shut off the power supply, this gets rid of the annoying clicking sound but then I can't use my convection. I am not sure which part to replace!! Please help.
I searched the existing posts but unfortunately could not find the answer to my issue.
Thank you.
;) Originally Posted by: khanalir my kitchen aid thermal convection oven works fine. the only problem is that the 4 gas burners igniter clicks even when the burner is on. for temp fix, i shut off the power supply, this gets rid of the annoying clicking sound but then i can't use my convection. i am not sure which part to replace!! please help.
i searched the existing posts but unfortunately could not find the answer to my issue.
thank you. that problem is usually the spark module. the part # is 4454392. some times a switch will short out, and create the same problem if you had a spill over on the switch, or got some fluid in there. if not i would go with the spark module. tom
