Discuss
Frigidaire range F30 Error
 in
My Frigidaire Range is flashing a F30 error code when you try to use the oven. the cook top still
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire range F30 Error
  #1 (permalink)
Old 08-05-2009, 04:30 PM
Junior Member
Stevr35 is on a distinguished road
Default Frigidaire range F30 Error
Model Number: GLeS389FSC   Brand: Frigidaire   Age: 1 - 5 years
My Frigidaire Range is flashing a F30 error code when you try to use the oven. the cook top still works as it should. From the error code list it say to check the Oven temperture probe and OHM it out. Mine checks 1091 @ 74 degrees just as the spec calls for. What should i check next?
Ads By Google
Related Models
Frigidaire GLET1031CS0 Frigidaire/laundry Center
Frigidaire GLET1031FS0 Frigidaire/laundry Center
Frigidaire GLET1041AS0 Lc - Frig Gallery
Frigidaire GLET1041AS1 Lc - Frig Gallery
Frigidaire GLET1041AS2 Frigidaire/laundrycenter
Frigidaire GLET1142CS0 Frigidaire/laundry Center
Frigidaire GLET1142FS0 Frigidaire/laundry Center
Frigidaire GLFC1326FW0 Frigidaire/freezer
Frigidaire GLFC1326FW1 Frigidaire/freezer
Frigidaire GLFC1526FW0 Frigidaire/freezer
Frigidaire GLFC1526FW1 Frigidaire/freezer
Frigidaire GLFC2027FW0 Frigidaire/freezer
Frigidaire GLFC2027FW1 Frigidaire/freezer
Frigidaire GLFC2027FW2 Frigidaire/freezer
Frigidaire GLFC2027FW3 Frigidaire/freezer
Frigidaire GLFC2528FW0 Frigidaire/freezer
Frigidaire GLFC2528FW1 Frigidaire/freezer
Frigidaire GLFC2528FW2 Frigidaire/freezer
Frigidaire GLFC2528FW3 Frigidaire/freezer
Frigidaire GLFU1467FW0 Frigidaire/freezer
Frigidaire GLFU1767FW2 Frigidaire/freezer
Frigidaire GLFU1767FW3 Frigidaire/freezer
Frigidaire GLFU1767FW4 Frigidaire/freezer
Frigidaire GLFU2067FW2 Frigidaire/freezer
Frigidaire GLFU2067FW3 Frigidaire/freezer
Frigidaire GLFU2067FW4 Frigidaire/freezer
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC30S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSB Frigidaire/gas Cooktop
Frigidaire GLGC30S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S9ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC36S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC36S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC36S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC36S9ESA Frigidaire/gas Cooktop
Frigidaire GLGF366ABA Frigidaire/range
Frigidaire GLGF366ABB Frigidaire/range
Frigidaire GLGF366ABC Frigidaire/gas Range
Frigidaire GLGF366ABD Frigidaire/gas Range
Frigidaire GLGF366AQA Frigidaire/range
Frigidaire GLGF366AQB Frigidaire/range
Frigidaire GLGF366AQC Frigidaire/gas Range
Frigidaire GLGF366AQD Frigidaire/gas Range
Frigidaire GLGF366ASA Frigidaire/range
Frigidaire GLGF366ASB Frigidaire/range
Frigidaire GLGF366ASC Frigidaire/gas Range
Frigidaire GLGF366ASD Frigidaire/gas Range
Frigidaire GLGF376DBA Frigidaire/gas Range
Frigidaire GLGF376DBB Frigidaire/gas Range
Frigidaire GLGF376DBC Frigidaire/range
Frigidaire GLGF376DBE Frigidaire/range
Frigidaire GLGF376DBF Frigidaire/range
Frigidaire GLGF376DBG Frigidaire/range
Frigidaire GLGF376DBH Frigidaire/range
Frigidaire GLGF376DCA Frigidaire/gas Range
Frigidaire GLGF376DCB Frigidaire/range
Frigidaire GLGF376DCC Frigidaire/range
Frigidaire GLGF376DCD Frigidaire/range
Frigidaire GLGF376DCF Frigidaire/range
Frigidaire GLGF376DQA Frigidaire/gas Range
Frigidaire GLGF376DQB Frigidaire/gas Range
Frigidaire GLGF376DQC Frigidaire/range
Frigidaire GLGF376DQE Frigidaire/range
Frigidaire GLGF376DQF Frigidaire/range
Frigidaire GLGF376DQG Frigidaire/range
Frigidaire GLGF376DQH Frigidaire/range
Frigidaire GLGF376DSA Frigidaire/gas Range
Frigidaire GLGF376DSB Frigidaire/gas Range
Frigidaire GLGF376DSC Frigidaire/range
Frigidaire GLGF376DSE Frigidaire/range
Frigidaire GLGF376DSF Frigidaire/range
Frigidaire GLGF376DSG Frigidaire/range
Frigidaire GLGF376DSH Frigidaire/range
Frigidaire GLGF377ABA Frigidaire/gas Range
Frigidaire GLGF377ABC Frigidaire/range
Frigidaire GLGF377ABD Frigidaire/gas Range
Frigidaire GLGF377ABE Frigidaire/gas Range
Frigidaire GLGF377ABF Frigidaire/gas Range
Frigidaire GLGF377ABG Frigidaire/gas Range
Frigidaire GLGF377AQA Frigidaire/gas Range
Frigidaire GLGF377AQC Frigidaire/range
Frigidaire GLGF377AQD Frigidaire/gas Range
Frigidaire GLGF377AQE Frigidaire/gas Range
Frigidaire GLGF377AQF Frigidaire/gas Range
Frigidaire GLGF377AQG Frigidaire/gas Range
Frigidaire GLGF377ASA Frigidaire/gas Range
Frigidaire GLGF377ASC Frigidaire/range
  #2 (permalink)
Old 08-06-2009, 05:28 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Quote:
Originally Posted by stevr35 View Post
my frigidaire range is flashing a f30 error code when you try to use the oven. the cook top still works as it should. from the error code list it say to check the oven temperture probe and ohm it out. mine checks 1091 @ 74 degrees just as the spec calls for. what should i check next?
that is a good reading, but sometimes it checks to be good when it is not. i read the code also, and it says replace sensor probe. but, the sensor probe plugs into the erc board, and that is where the problem could be. so my friend it is a toss up. you could replace the sensor, and see if it works. if not, the board will be the issue. that is the best way to approach it. when a erc board is bad, i usually sell the sensor also. its just a good way to go, because, sometimes a bad board could damage a sensor. tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
Frigidaire Smooth Top Electric Range F30 Error vanbao Oven Repair (including Ranges and Cooktops) 2 11-01-2009 05:38 AM
frigidaire error hemion20s Oven Repair (including Ranges and Cooktops) 3 04-11-2009 07:36 PM
F3 Error on Frigidaire over the range microwave dignupfax Microwave Repair 2 01-29-2008 09:26 PM
Frigidaire Gallery Range FP5 Cooktop Error dmccoy Oven Repair (including Ranges and Cooktops) 0 09-21-2007 07:00 AM
