Discuss
No Oven
 in
Igniter lites but oven will not lite. 1.120v going into thermostat 2.120v coming out of thermostat 3.2.4v at gas valve
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No Oven
  #1 (permalink)
Old 01-11-2008, 10:53 AM
Junior Member
hee@hardinnet.com is on a distinguished road
Default No Oven
Model Number: crg7500aal   Brand: Maytag   Age: More than 10 years
3.2.4v at gas valve
4.Gas valve says not to put 120v to it.
5.Gas valve rated 3.0-3.3v
Wiring diag.does not show a resistor,unless its in the wire.
So any help would be greatly apprecaited.
Also how important are the gaskets under the top sealed burners?I have 2 that have disintegrated.
After looking a little further.apparently the wiring goes thru the igniter to reduce the voltage to the gas valve.when the ingniter is on ,the top bar glows white and the lower part glows red.If I read an other post on here it should be glowing white all over.Could there be a crack that I can't see be causing the voltage to drop to the gas valve.Or is the igniter just not getting hot enough to turn the gas on? Using a meter I got a reading of 196 ohms resitance on the igniter which does'nt help me because I don't know what its supposed to be.
Thanks in advance
Ads By Google
Related Models
Maytag CRG7500AAL RANGE- F/S STD GAS
Maytag CRG7500AAW RANGE- F/S STD GAS
Maytag CRG7500CAE RANGE- F/S STD GAS
Maytag CRG7500CAL RANGE- F/S STD GAS
Maytag CRG7500CAW RANGE- F/S STD GAS
Admiral CRG7500CGE RANGE- F/S STD GAS
Admiral CRG7500CGW RANGE- F/S STD GAS
Maytag CRG755 RANGE- S/C F/S GAS
Maytag CRG760 RANGE- S/C F/S GAS
Maytag CRG7600AAL RANGE-F/S CONT CLEAN GAS
Maytag CRG7600AAW RANGE-F/S CONT CLEAN GAS
Maytag CRG760A RANGE- S/C F/S GAS
Maytag CRG7700AAL RANGE- F/S STD GAS
Maytag CRG7700AAW RANGE- F/S STD GAS
Maytag CRG7700BAL RANGE- F/S STD GAS
Maytag CRG7700BAW RANGE- F/S STD GAS
Maytag CRG7700CAL RANGE- F/S STD GAS
Maytag CRG7700CAW RANGE- F/S STD GAS
Maytag CRG783 RANGE- S/C F/S GAS
Maytag CRG800 RANGE- S/C F/S GAS
Maytag CRG805 RANGE- S/C F/S GAS
Maytag CRG8200AAL RANGE- F/S STD GAS
Maytag CRG8200AAW RANGE- F/S STD GAS
Maytag CRG8200BAL RANGE- F/S STD GAS
Maytag CRG8200BAW RANGE- F/S STD GAS
Maytag CRG8200CAL RANGE- F/S STD GAS
Maytag CRG8200CAW RANGE- F/S STD GAS
Maytag CRG8400AAL RANGE- F/S STD GAS
Maytag CRG8400AAW RANGE- F/S STD GAS
Maytag CRG860 RANGE- S/C F/S GAS
Maytag CRG8600AAB RANGE- S/C F/S GAS
Maytag CRG8600AAL RANGE- S/C F/S GAS
Maytag CRG8600AAW RANGE- S/C F/S GAS
Maytag CRG8600BAB RANGE- S/C F/S GAS
Maytag CRG8600BAL RANGE- S/C F/S GAS
Maytag CRG8600BAW RANGE- S/C F/S GAS
Maytag CRG860A RANGE- S/C F/S GAS
Maytag CRG9300CAL RANGE- S/C F/S GAS
Maytag CRG9300CAW RANGE- S/C F/S GAS
Maytag CRG9600AAL RANGE- S/C F/S GAS
Maytag CRG9600AAW RANGE- S/C F/S GAS
Maytag CRG9700AAL RANGE- S/C F/S GAS
Maytag CRG9700AAW RANGE- S/C F/S GAS
Maytag CRG9700BAL RANGE- S/C F/S GAS
Maytag CRG9700BAW RANGE- S/C F/S GAS
Maytag CRG9700CAE RANGE- S/C F/S GAS
Maytag CRG9700CAL RANGE- S/C F/S GAS
Maytag CRG9700CAM RANGE- S/C F/S GAS
Maytag CRG9700CAW RANGE- S/C F/S GAS
Admiral CRG9700CGE RANGE- S/C F/S GAS
Admiral CRG9700CGM RANGE- S/C F/S GAS
Maytag CRG9800AAB RANGE- S/C F/S GAS
Maytag CRG9800AAE RANGE- S/C F/S GAS
Maytag CRG9800AAL RANGE- S/C F/S GAS
Maytag CRG9800AAW RANGE- S/C F/S GAS
Maytag CRG9800BAB RANGE- S/C F/S GAS
Maytag CRG9800BAE RANGE- S/C F/S GAS
Maytag CRG9800BAL RANGE- S/C F/S GAS
Maytag CRG9800BAM RANGE- S/C F/S GAS
Maytag CRG9800BAW RANGE- S/C F/S GAS
Maytag CRG9800CAB RANGE- S/C F/S GAS
Maytag CRG9800CAE RANGE- S/C F/S GAS
Maytag CRG9800CAM RANGE- S/C F/S GAS
Maytag CRG9830CAB RANGE- S/C F/S GAS
Maytag CRG9830CAE RANGE- S/C F/S GAS
Maytag CRG9830CAM RANGE- S/C F/S GAS
Admiral CRGA250AAL RANGE- F/S STD GAS
Admiral CRGA250AAW RANGE- F/S STD GAS
Admiral CRGA250BAL RANGE- F/S STD GAS
Admiral CRGA250BAW RANGE- F/S STD GAS
Admiral CRGA300AAL RANGE- F/S STD GAS
Admiral CRGA300AAW RANGE- F/S STD GAS
Admiral CRGA300BAL RANGE- F/S STD GAS
Admiral CRGA300BAW RANGE- F/S STD GAS
Admiral CRGA350AAL RANGE- F/S STD GAS
Admiral CRGA350AAW RANGE- F/S STD GAS
Admiral CRGA400AAL RANGE- F/S STD GAS
Admiral CRGA400AAW RANGE- F/S STD GAS
Admiral CRGA400BAL RANGE- F/S STD GAS
Admiral CRGA400BAW RANGE- F/S STD GAS
Admiral CRGA500AAL RANGE- F/S STD GAS
Admiral CRGA500AAW RANGE- F/S STD GAS
Admiral CRGA600AAL RANGE- S/C F/S GAS
Admiral CRGA600AAW RANGE- S/C F/S GAS
Admiral CRGA650AAL RANGE- S/C F/S GAS
Admiral CRGA650AAW RANGE- S/C F/S GAS
Admiral CRGA700AAL RANGE- S/C F/S GAS
Admiral CRGA700AAW RANGE- S/C F/S GAS
Admiral CRGA800AAE RANGE- F/S STD GAS
Admiral CRGA800AAL RANGE- F/S STD GAS
Admiral CRGA800AAW RANGE- F/S STD GAS
Frigidaire CRGF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CRGF342AS1 Dryer - Frig/best Buy
Frigidaire CRGF342AS2 Frigidaire/gas Range
Frigidaire CRGF342AS3 Frigidaire/gas Dryer
Frigidaire CRGF342AS4 Frigidaire/dryer
Frigidaire CRGR442AS0 Dryer - Frig/best Buy
Frigidaire CRGR442AS1 Dryer - Frig/best Buy
Frigidaire CRGR442AS2 Dryer - Frig/best Buy
Frigidaire CRGR5700AS0 Dryer - Frig/best Buy
Frigidaire CRGR5700AS1 Frigidaire/gas Dryer
Frigidaire CRGR5700AS2 Frigidaire/gas Dryer
Frigidaire CRGR5700AS3 Frigidaire/dryer
Frigidaire CRGR7900AS0 Dryer - Frig/best Buy
Frigidaire CRGR7900AS1 Frigidaire/gas Dryer
Frigidaire CRGR7900AS2 Frigidaire/gas Dryer
Frigidaire CRGR7900AS3 Frigidaire/dryer
Amana CRH4-1 COMMERCIAL MICROWAVES
Amana CRH4-3 COMMERCIAL MICROWAVES
Amana CRH5-1 COMMERCIAL MICROWAVES
Amana CRH5-3 COMMERCIAL MICROWAVES
Admiral CRL5300BXA RANGE- F/S STD GAS
Admiral CRL5300BXW RANGE- F/S STD GAS
Admiral CRL5300CXL RANGE- F/S STD GAS
Admiral CRL5300CXW RANGE- F/S STD GAS
Admiral CRL5300DXL RANGE- F/S STD GAS
  #2 (permalink)
Old 01-12-2008, 03:43 PM
Junior Member
Default
Fixed it my self local dealer had an igniter and now its working again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
