I have replaced the control interface, upper and lower elements, sensor, and thermostat fix. Each time when the power is returned to the unit the oven will begin preheating and both upper and lower element will heat. Once you stop the heating process and try to restart the unit will not heat again until it is disconnected from the power source. Please help..................
Groups: APP Team
Hi. The problem could be with bad electrical connection at disconnect plugs. See if you can check all of them.
Also, is there power to the control board?
Post the result.
