I have a 40 year old frididaire wall oven RBG-94K
I replaced the control/thermostat unit part number 5306564063 but the broiler element does not come on when set to broil, but the bake element does. Bake element works also when set to bake also
What I need is a wiring diagram. The drawing I made when I took the unit apart was lost and I had to reconnect the wires by memory. There are teminal numbers 1,2,3,4. labled on the thermostat. I need to know what wire goes where.
Any suggestions would be helpful
