Discuss
Oven won't heat up
 in
Repairman said control panel went bad, so we ordered one, installed it, all the buttons work, clock, etc. Only, the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't heat up
  #1 (permalink)
Old 01-10-2008, 11:07 PM
gpmcmahan gpmcmahan is offline
Junior Member
gpmcmahan is on a distinguished road
Unhappy Oven won't heat up
Model Number: MER5755QAB   Brand: Maytag   Age: 1 - 5 years
Repairman said control panel went bad, so we ordered one, installed it, all the buttons work, clock, etc. Only, the oven won't heat up. The oven temp starts at 100 degrees. Doesn't seem to want to go up from there. However, if we cancel and turn on broil HI for just a second, then cancel that and turn the oven back to 350 degrees it will begin to heat up, but takes forever. Only got to 175 in about 15 minutes. What's up!!!! Could the bottom element be bad also? Well, the element was broken, so replaced it with a new one and still the bake element will not get hot. Help!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
oven will not heat hulaboy Oven Repair (including Ranges and Cooktops) 12 01-23-2008 02:49 PM
Bosch 27" Dbl oven Powering on but no heat either oven badace Oven Repair (including Ranges and Cooktops) 0 12-02-2007 10:56 AM
oven doesn't heat up Saskia Oven Repair (including Ranges and Cooktops) 4 11-26-2007 11:17 PM
Oven will not heat lznuk Oven Repair (including Ranges and Cooktops) 1 11-16-2007 06:09 PM
Oven won't heat ctlopez Oven Repair (including Ranges and Cooktops) 0 10-03-2007 09:47 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
